Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
innovation_station
it is repaired .. that was odd ...
anyhow .. looks like garys secondary is feed back ...
perhaps ...
ist
gadgetmall
Quote from: Groundloop on December 11, 2009, 12:53:39 PM
Albert,
Mail me your JT drawing in a bigger size that was in your document.
I will update the word document and mail it back to you.
Alex.
Done . I have a zoom button so it ZOOMs right in on that little pic . I could not for the life of me figure out how to enlarge that dang tinycad drawing with the information in the bottom right SOO i just sent you the diagram .
Albert
resonanceman
Quote from: jeanna on December 11, 2009, 01:37:30 PM
@Gary,
Thanks, I will stand by and watch.
I am not clear how you are using the external thing and how it is called a secondary if it is external??
Jeanna
Look at the  the 2 first pictures  you posted for me.
The  first one is called  Candy Cane
The second one  is called Candy Cane2
The only difference in the coil is the 2 extra windings that I added  AFTER all the other windings  were done ........and after I had  written down  all the voltages I  had got  from the original  windings  .
What wouldl you call  these new windings ?
I called them external  .....because they are external to the original  windings and core
In the 3rd picture   you will see a simplified  version  ......it only has  2 windings ........the primary is  a brown and white twisted pair ... it spans several toroids . .
The  secondary   is the orange wire  that I called  external
I did not have enough  space in the  center to add more  wire to the secondary  .......a bigger  toroid is needed
hope that this helps
gary
IST  no feedback ........yet
jeanna
Thanks Gary.
I guess it is just called the secondary. That is unless it is the one that is connected to the transistor which would make it the primary.
I believe that the secondary is what it is even though it encompasses all those toroids.
My conical is not as much a secondary as it is another coil in series, because it only has a few wires wrapped around the toroid, and the rest are going off to who knows where as a 2 wire cone.
Both of these are pushing the boundaries of our definitions and I want to stay on top of them, because I know I will get confused and eventually lost if I don't.
So, thanks for the explanation.
jeanna
resonanceman
Quote from: jeanna on December 12, 2009, 12:37:59 AM
Jeanna
here is something else to stay on top of
This  is a different configuration  of  my candy cane  coil
Like  my  candy cane coil  the primary  of this coil  spans several toroids . ( brown )
The secondary  goes through  the centers of all the toroids  but does not wrap around any of them .
The  secondary   ( orange ) originally  put out 50 V measured  with a small cap and a bridge
I tried  lowering  the  voltage  by  increasing   the base resistor .
I had to add 18K to get my pot to a workable range so I could hit 2.5V
At that power setting  the ultracap did not charge
I  did not  take reading and  figure out  how much the ultracap was going up per minute .......but with full power this coil  was charging faster than candy cane3 did the other night . probably  because of  a larger  secondary
The  green coil  is there to  experment  with feedback ...... This coil  did not  have much power     I might have got the  windings the wrong direction
With other  feedback experments  this coil  would light up my LED array very brghtly
gary
