New Jewel Thief "Resonate LCR Circuit" Much less energy draw....
Started by sirmikey1, January 01, 2010, 09:25:10 AM
xee2
Quote from: sirmikey1 on January 02, 2010, 11:08:33 PM
  I hear that 20 turns primary with 200 turns secondary does much better. That 4kv trigger coil is probably the think to do:
http://www.mouser.com/Search/Refine.aspx?Keyword=4kv+trigger
Yes, 20:200 should give higher output voltage. That is the advantage of having a secondary. The secondary does not have to have two coils, the trigger coils should work also (however I have some concern over the high resistance of the coils you referenced above but I think they should work).
EDIT: drawing modified
sirmikey1
Hi all,
    Does anyone know what type ferrite to buy?  There's a few dozen different types.  I'm seeing type 25, 28 43, and 47 on ebay, so far.
Thanks in Advance,
MIkey
xee2
Quote from: sirmikey1 on January 03, 2010, 03:32:37 AM
Hi all,
Thanks in Advance,
MIkey
If you are going to make a transformer for the Joule thief, you should use high permeability material.
Note that I modified the diagram to match the spec sheet for the trigger coil you referenced above. Those coils seem to be the equivalent of mini ignition coils.
sirmikey1
xee2,
  Are you "off the grid" yet? Thanks for all, very helpful.
Mikey
sirmikey1
