Groundloop
mikestocks2006
Magluvin
Honestly, closing the loop in the way you suggest is the best thing I have heard in all this thus far. Reed switches are cool, as I have fair experience with them.  Now what would be very interesting is, eliminate the electronics and use a reed to connect the charge coil to the toroid at the right time. This may be just enough to let her spin without the batteries. Of course some playing with the charge and toroid coils size and no. of windings of which there will be many combos, but it just might work considering the low consumption of the toroid coils. Awesome thought there.
Good luck all
Magluvin
Bruce_TPU
Evening ALL,
I worked with a nifty switching circuit today from JDO300.  Basically a reed switch, switching a power mosfet.  Circuit works great but we found out what my problem has been all along...My toroids.  It seems that the cores, of which I have had for years, are of the type that do NOT saturate easily but require a great deal of current, and they are also too large, nearly 2.25 inches in diameter.
So, now I will order the proper toroidal cores and try once again... LOL  Frustrated and ready to see this dude spin...  ;)  And I also have all of my parts arriving tomorrow to replicate Jean Naudin's circuit, but will wait until I have wound a proper coil.
Cheers,
Bruce
Magluvin
Dont get me wrong Mike. Im not taking any credit here from what I said.  It is a suggestion for Ozzie's position of the charge coils. I cannot see if there are 8 or 4 mags on the rotor. But if that were the case, the reeds would be appropriate. Having large charge coils over the toroid may have altered affect on the toroid as a core, as in it may cause an attraction/drag where ya dont want it. a larger dia rotor could separate things well enough. I just may give this a go myself. =]
mags
