Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
ramset
FatBird,
Tony has said this from the very first[the 5 year old "Killed" in Chicago]Thus the very light gauge wire he insists on.
BTW Very different than Bobs design.
Chet
PS has anyone tried this??
http://www.associatedbag.com/product.asp?cn=ABC&c1=BGB&p1=BGB
instead of waiting for glue to dry
apply double sided tape to tube for 1st layer , install light gauge wire than cover with above to keep everything straight.
Then put on second layer of heavy wire.
Thanks Grandma
agentgates
Quote from: teslaalset on January 12, 2010, 05:56:18 PM
What's the height of your new coil?
That was calculated by my formula I sent earlier at every 45 degrees coils:
l = (d x 3.14) / 6
"l" is the length you need to cut to get the 45 degrees. :)
UPDATE
Oh, pardon, to be complete: the length is ~67mm. :)
Magluvin
Hmmm Key,  by looking at that Phat =] secondary, made me think should the start of the secondary be, lets say we go clockwise from the start, above or below the secondary end. Just the from an angle standpoint and secondary proximity to itself, might affect the spins.  Like do we start at the bottom and end at the top? Or the other way. Just a thing to try. It is an open option.
Magluvin 07
I started remaking the 3d renditions with the correct angles, I will probably finish it up tomorrow.
agentgates
@ramset
Thanks, yes I did try that earlier but not easy with a thick and hard copper. I think I will try the hot glue thing next time. This one is very annoying and stink. I have to keep window open in this cold winter... :D
