PaulLowrance
Joule heating was calculated by doing a control experiment. The tiny orbo was rotating at 3450 rpm's during the main and control experiment. By using the video camera and a timer, the time it took for the tiny orbo to decelerate by 180 rpm's was recorded. The mass of the NdFeB magnets and also the black plastic *outer rim* were calculated. So far I have no calculated the rest of the tiny orbo mass, which would be an appreciable amount. Then the kinetic energy was calculated from the mass and velocity at 3450 and 3270 rpm (180 rpm difference). This gives the joule losses, and the power was calculated from the joule loss and the time duration.
Bruce_TPU
Hello ALL,
You can see my ongoing build video 1.2 here, as I continue to work on the mechanical while I await my cores, and my magnets.
http://www.youtube.com/watch?v=ZHMr4sXclq4
Cheers,
Bruce
callanan
Hi All,
A good place to find a hall sensor is in DC brushless fan motors. The kind typically found in PCs & power supplies. Here an old faulty one I have opened. See pics below.
Also, here is a link to the datasheet for this sensor.
http://www.bcdsemi.com/upload/datasheet/AH276%20D1.3%2020080619.pdf
The fan it came from was a 12V 1.1W DC brushless fan. As you can see in the datasheet, the hall sensor has a wide voltage operating range and is very versatile.
There are plenty of these fans lying around in many old and faulty pieces of equipment like PC power supplies so you can save some money getting the hall sensors out of them...
Ossie
gravityblock
Quote from: PaulLowrance on January 17, 2010, 08:06:14 PM
I hate to get everyone's hopes up, but this is a very sincere post. IMO this tiny orbo is over COP 1 when not considering electrical resistance from the wires and mosfet.
In my opinion this system and concept is OU.  From an engineering view, it is extremely brilliant.  This is the real deal.  We will all be believers in due time.
I appreciate all who provided me with links for the oscilloscope.  Thanks Ossie for the information on where to get the Hall Sensors in order to save money.  I may be one of the last to have a self-runner due to my very limited budget, but all of these cost savings will make it possible.
Thanks to everyone for making this a real possibility,
GB
gravityblock
Ossie,
Any chance of there being a metglas core inside the PC Power Supplies, LoL?
I have an old power supply opened up right now and there is a small toroid that is highly attracted to my magnets with what appears to be a black plastic case.
GB
