Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
rave154
BRUCE ,  hoooray!!!!
are you going to cast the coils INTO the cores or wrap them around the cores?
synchro1
I tested a copper wire coil wrapped steel wire spiral pancake coil today. I sandwiched the spiral between two ring magnets N and S facing each other. The magnets were both attracted by the hay wire core in between. When the copper magnet coil wraps were energized by a short 12 V charge, the magnets continued to cling, not to the steel core, but by mutual attraction. When placed in proximity to a larger stack of ring magnets, the sandwich demonstrated a marked repulsion when charged. This proves that the wire coil pancake trigger links the flux between the ring magnets on each side when charged, and nullifies it when inert.
Bruce_TPU
I have received in all of my casting ingredients.  Elmers fiberglass resin, iron oxide powder and activated charcoal.  I am simply a bit stymied because I have yet to be able to saturate my metglass toroid.  I am now trying LarryC's idea which is to wind a secondary, short the secondary, and then wind the primary on top.  I NOW also believe that Steorn had a hidden secondary under their primary.  When I get this toroid to saturate and lose it's magnetic attraction, I will be ready to roll.
Cheers,
Bruce
http://energyfreedomreport.com
synchro1
This is off topic, but I got an idea for a new motor. Imagine a stack of magnets behind the spiral flux blocker for a stator, and a stack of rings on the rotor in polarity opposition. The rotor magnets would be attracted to the metal in the spiral core as they came around, then when they hit the sticky spot, the copper wire wraps would be energized, not just to eliminate the attraction, but to expose the rotor magnets to the full opposition force of the stack hidden behind the flux blocker spiral. This is an Orbo with a high tourque booster. I think I'll move ahead and try and build this one.
Bruce_TPU
Hi Mags,
I have a question for you and wrote that question on your picture that I am reposting.  I look forward to your answer...  ;)
Thanks!
Bruce
http://www.energyfreedomreport.com
