Jimboot
Quote from: Pirate88179 on January 31, 2010, 08:27:06 PM
Jim:
Your probes go in series with the positive lead on the run battery to measure amp draw.
Hope this helps.
Bill
Thanks for helping the noob!
Bruce_TPU
Hello ALL,
In the youtube Steorn Demo, at 2:54 -2:57 Sean say what is true.  "There is a lot more power that we can capture."
They have only ONE pick up coil but there is room for more, not to mention adding the second level generator.  As far as I am concerned it is pretty conclusive, via the scope shot, as Omni also pointed out.
I think we need to think "outside" the box with the generator ideas for our motors, and push it to the limit!
Cheers,
Bruce
http://www.energyfreedomreport.com
Jimboot
Quote from: Bruce_TPU on February 01, 2010, 01:24:08 AM
Hello ALL,
Cheers,
Bruce
I'm with you on that! I'm currently thinking about a 2nd lvl generator for my Ossie motor. Because I'm getting 2400RPM & it feels to the touch that it is capable of some work
Jimboot
Listening with a stethoscope to the 'hissing' of the coils on my Ossie Motor, it sounded like water trying to get through a garden hose when you kink it.
Jimboot
Been running 20 hours non-stop 2800RPM battery down to 5.6Volts. Truly amazing Ossie! Thanks
edit: Ok hold the press. I was reading the tacho wrong. Divide all my reported RPMS by 3. Still fast I think for a motor I had running nearly 22 hours b4 I switched off. Sorry for my noobiness.
