Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
Honk
Quote from: CLaNZeR on January 09, 2007, 04:54:53 PM
Quote from: JackH on January 08, 2007, 08:37:13 PM
Hello All,
Just thought I would post some pictures of the new Hilden-Brand motor in it's current stage.   This motor is 29" long by 17" high.  This is the first three valve motor I have built.   Each rotor should have over 1900 lbs of magnetic pull on it.  As to my calculations it should run on not over 400 Watts, and produce around 4 to 5 HP.  Hope to have it finished up in about three weeks.
Later,,,,Jack W Hildenbrand
Excellent Jack
That looks damm sweet.
Good luck with the experiments and keep us all informed.
Sean.
Hi all.
I recently discovered the Hilden-Brand Motor and have been reading
all about it for the last couple of days.
The new 5Hp motor sounds great, but where can I see the pictures.
They were not attached to the original message, as what I could see?
Good luck with your Super Motor and the goal of Over Unity.
Magnet Power equals Clean Power
JackH
Dingus Mungus
Honk
WOW... Very nice work, Jack.
I can clearly see the resemblance to a combustion engine.
It's very much like a 3 valve ICE and you could probably make it into a 6 valve
motor, if you felt like it.
Instead of firing of sparks to ignite the gas you fire of low energy but high power
magnetic pulses to attract the rotor.
Very genius. The Magnetic Valve is truly a super invention.
I look forward to read about your continued progress.
In particular when you hook up a good generator to the shaft and try to get
it self running. This would mean a paradigm shift in the world of science and you
would get recognized as the man who saved the world from oil dependence.
pg46
Wow! She's a beauty!
Real nice machining Jack. I'll look forward to seeing it run.
All The Best
