Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Bruce_TPU
Hello ALL,
Can anyone say...WEIRD..lol.  I just added a blue LED, this is the third in series, brightly lit, and NEW output voltage....   8 volts  !!!
New output voltage frequency....  330 Hz
Now, a few things you should remember:
A.  I am working with "Brook's Coils", all wound professionally (three so far)
B.  Could the LED's somehow be increasing the frequency within these Brooks pick up coils and as the frequency increases, so does the output voltage?
Time to add some more LED's...  I still have three more coils I plan on adding, but first tonight, time for more LED's.
Resistance in Ohms of output coils = 753 Ohms
Output voltage = 8 volts
Cool stuff,
Bruce
http://www.energyfreedomreport.com
Magluvin
Hey Bruce
I have some pretty good experience with LEDs.
Are the leds the same? Color,  model?
If you have them in series, your output is no longer being clamped by the single led's running voltage, to say it the easy way. Now you have 2 in series, that clamp voltage is 2 times as much, 2 times the drop or clamp. The led's wont take current till the voltage rises to the running voltage, and if it draws from the output if it goes below the running voltage the draw stops and voltage rises again from there when currents are weak with an unstable voltage.  Also if it is bouncing from run to not run, it could be oscillating enough to get the leds go into overdrive, which happens with short pulses, thus more brightness. If you check on a scope you might just see it osc. If not and the output is stable with a cap, they could be just hovering in the on off area and some other factor is giving extra brightness. Its hard to say without seeing what you have going for sure.The JT's are definitely putting the leds into overdrive, so thats why the are soo bright with little current due to the short pulses and high freq. Some laser diodes use pulse circuits also to get them to overdrive.
Hope that makes sense.  =]
Mags
Magluvin
8 volts across a blue led? It should be about 4 to 5v clamp. So you must be putting out some juice.  It just may burn the led without a limit res.
Good to see it coming together. I have messed with orbon for quite a while and it just doesnt seem to stop  surprising me with these lil tweeks and increases.
oh, are you using a limit res on the led?  That could be why the 8v is not burning it.
Mags
Bruce_TPU
Hi Mags,
Two LED's are the same, and one is differant.  Tomorrow, I will have all three the same.
The setup is VERY sensitive.  ALL magnet orientation must be correct to get the Maximum output.  I have attached a simple drawing to help everyone understand, and to keep lab notes.
I tore it apart carefully, so that I can repeat it tomorrow evening.  The magnet facings AND placement are critical!  If I change on facing, cuts output in half!
I can now, turn the rotor by hand, slow motion, and when the reed switch switches the circuit, my three LED's light.  It's pretty cool.
I might make a vid tomorrow night.  I'd rather experiment some more, though.  I still want to optimize and think some things through.
Realizing the the magnet in the center of my toroid MUST be SOUTH facing the bar magnet (mag in toroid is horizontal, bar mag is vertical) to keep from cutting the output in half, has given me some whole new ideas to boost power with more magnets.  I am realizing, if you just "add" magnets and nothing happens, it may be because their position relative to everything is not correct.
Cheers,
Bruce
aaron5120
Quote from: Bruce_TPU on February 24, 2010, 09:43:16 PM
Hello ALL,
Cool stuff,
Bruce
Bruce,
Could you please tell us what is the input voltage and current to your Circuit? At what duty cycle? Is it pulsed DC?
Can you tell us also the consumption current of your load( the leds)?
Thanks for your attention. Keep going on, Good experiment, Bruce.
