The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
infringer
but just think how this could revolutionize current electric motors for different tasks imagine your cd player or even portable DVD player lasting 10x's as long or your hard disk drive sipping power as if it were a mouse of current day ... This could easily lead to longer lasting batteries using current laptops or desktops even its really more then just simply a motor you could charge this capacitor then not charge it again until the voltage reaches "x" level or amount that requires a quick charge in doing so we have a very efficient motor more then anything currently available now...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
Bruce_TPU
Hi Jim,
I think I read that 1 Farad of a supercap is equal to 1 Amp Second.  You are running on about 1.5 ma's?
A 55 Farad Supercap would give a rather long run I think.  Sorry my friend.
You should look into Lutec's pulse motor generator.  Interesting how they harvest the produced AC off of the same DC pulsed coils.  It might be a way...
Cheers,
Bruce
Jimboot
Quote from: Magluvin on March 19, 2010, 11:36:14 PM
Jim
Hook the pickup coils leads to the ac side of a bridge rectifier and the dc out to a cap. 100 to 1000 uf  16v or more.
Then measure the caps charge.  And if you put a little light bulb or a 10ohm res, you can read the voltage and current to figure your watts out, as compared to your watts in.
Mags
Ok I've hooked up a coil from a rechargable torch. I have a 1000uf 35v cap & I have used a bridge rectifier (one I prepared earlier) that I made for another ossie circuit using schottkies . The cap quickly charges to 3.3 volts if I try hooking up a globe or a battery to charge tho my motor stops. Presumably because I'm altering the field in my drive coils with my pu coil current draw?
Anyway I'm thinking I should hook up a 2nd in series and that will give me over 6v that I can feed back into my drive battery? Maybe use a diode that only lets the current pass when over 6v? Once I get that happening - as long as I'm not dreaming I'll switch to a single D cell then try the supercap.
Jimboot
Quote from: Bruce_TPU on March 20, 2010, 11:13:41 PM
Hi Jim,
Cheers,
Bruce
Yep I realised my mistake. A 45 min run. Nice but no cigar :) Back to the pu coils.
Jimboot
Quote from: Rapadura on March 20, 2010, 10:42:53 PM
Running 45 minutes just on one supercap is very impressive. 45 minutes is not 45 seconds. It's a lot of time! Very good!
Thanks but I'm looking for something I can eventually put in a Tesla sports car :) I have no idea if it's impressive but I am at least impressed I have learned a lot :D
Back to work now.
