Graphite-Paper - Aluminium-Foil galvanic cell with 1.7 to 1.92 Volts
Started by hartiberlin, February 17, 2010, 01:39:32 AM
FreeEnergy
how about a baghdad battery or an egyptian light bulb wouldn't that be a better alternative(s)?
Well the baghdad battery:
http://patentpending.blogs.com/patent_pending_blog/2004/10/the_baghdad_bat.html
used iron and copper.
The usage of the alufoil-graphite cell is that the
graphite electrode will not be used up and only
the cheap alufoil will be used up, which could be replaced easily.
I will working further on this to get 1 Watt LEDs to power with it
constantly.
Regards, Stefan.
the badger
Wouldn't using recycled aluminium pop cans be cheaper (free) and being thicker also last longer than aluminium foil? Just an idea. :)
Yes, alucan would be better, but over here in Germany all cans
are mostly from zinc metal I believe and not from Aluminium.
Which brands in Germany are from Aluminium ?
As I don´t drink any beer nor any Cola I dont know
much about the different beer cans... ;)
ResinRat2
Hi Stefan,
What do you think about using your invention to charge batteries, or perhaps even a Cap? That way it would probably give a more even voltage output for further use; and you would waste less of the energy produced as well.
Also, since you really can't turn off the reaction, it might be a way to just run it and store the energy.
Thanks again for posting your progress.
RR2
