The Ossie motor
Started by robbie47, February 02, 2010, 03:53:17 AM
Jimboot
@gyula Thanks mate. Feel like I'm being helped along by giants here :). Everytime I think of lenz law I think of Stan Deyo's work. Rightly or wrongly. It just pops into my head. How can use that reaction rather than eliminate it. I have strpped it down and am running on a single D cell atm. I am thinking of aligning the pu so they each face a mag at the same time. That should at least eliminate them affecting the drive coil. In this pic it is running at 1.33 v & less than .01A doing 420 rpm. It's much more sensitive to tune tho.  Got my booby wave trace back tho :)
Jimboot
@woopy where are you at? @neptune? Has life got in the way? :)
Jimboot
Left it running on one coil no pu overnight voltage is slightly higher than b4 I went to bed.
Jimboot
Amps are registering below zero on my 1amp panel meter. 830rpm. 1.32v . The amp needle is constant just under zero. Single d cell 1 drive coil. ABout to attempt a cap run. Then back to pu coils.
Jimboot
Volts drop very slowly on cap run but still drop. Back to pu
