Fibonacci, platonic solids and Vortex coils
Started by Mk1, March 09, 2010, 10:39:44 PM
Mk1
Quote from: stprue on March 25, 2010, 08:40:27 AM
Hello Mark
Great video, you are making some really great progress with your coils.  Is there an ideal distance between the coils when you add all 3 together inside one another?  I was thinking that maybe it would be a good idea to try to make a 3 layer coil instead of 3 separate coils.  What do you think?  It may be worth the effort.  Anyways keep up the great work
~Stew
Actually i have found a new way to wind the coil without the cardboard, i will show it soon ...
Mark
Edit , i don't believe in a design built with more then one freq per core , the most you can put on is two phase ...
Like the tpu 3 freq Idea you need 3 core of that i am sure .
Mk1
Quote from: jeanna on March 25, 2010, 01:58:39 PM
Mark,
This is really wonderful.
I have a question about what is powering the motor.
It is the secondary pickup of the big coil, but it seems to be a separate circuit from a separate battery.
Is it?
You are breaking all the walls around the box... again.
Great stuff.
jeanna
You got it , not connected to anything and running bulb and motors ...
I could run bulbs and led from the jt coil  ;)
That is why i made it into a movie.
Thanks again for your support.
Mark
edit i will ad comments ...
wattsup
Yeh Yeh nice LED play, Rotor play, Spark play and Guitar play. I wonder if Tesla played an instrument. The DC Fiddle.
Is it not fun to play with those coils.
So everybody come and see what this guy made. The beginnings of the 6TPU.
The circular of the 6TPU and also could be a rectangular like the LTPU wall.
Now make 12 or more of these in rectangular standings vertical all in a circle and you have an LTPU. Cut out a piece of it and with some simple reconnection, you are off again.
It just remains to make it grow with gain.
The outer pick up wind wound be vertical on the exterior like we see in the LTPU video. The outer wind.
MK1, sorry to post this here but I just wanted to put it here because it is from here it came.
OK, here is what I think. If it works with thin wire, It will work more with thicker wire but in the same wind pattern. That could explain the weight of the LTPU.
Man oh man. Thanks.
wattsup
ElectricGoose
Quote from: Mk1 on March 25, 2010, 04:16:03 PM
Actually i have found a new way to wind the A without the cardboard, i will show it soon ...
Mark
Mark
Great posts mate!  I am having a few issues though and can't seem to replicate the output power you are demonstrating in your video's.
I'm not sure if it comes down to number of winds, overall frequency, your circuit, input power or what but I have tried everything including every which npn/pnp configs, not withstanding facing North, wearing an Aluminium Pyramid hat whilst holding onto a copper water pipe!  :D :D  I did NOT get much radiant but I may have contacted Elvis from beyond!
OK, so all funnies aside, some queries.
1)  What's your input power?  (1.5 volt?)
2)  Are you doing something out of the ordinary with the circuit?  I have tried additional coils, darlingtons etc etc and whilst I am seeing the standard power/spikes/lamp lighting from the EC of transistor, I CANNOT light a lamp at the EC AND the SECONDARY coil without killing the EC lamp which means the freq might not be high enough.  Can you post your circuit?
3)  I have asked this before - is there a problem bringing the coils/winds closer together?  I assume this is part of the 'nuance' of the agentgates coil.
4)  You are rectifying the current from a collector coil before feeding it to the led right?  (Either way, my meter is picking up just about zero AC on any coil I drop inside the field!
Look forward to a reply.
E-Goose
Mk1
Egoose
1)  What's your input power?  (1.5 volt?)  1.25 rechargeable 2440 mili
I don't use diodes or meter for that mater , a good transistor to test is 2n2222 and 2n3409 .
I can't say for sure the on the spacing part , but you need many revolution and turns .
Non no need to ...
I will need to see a picture ...
