GBluer(Slayer) Exiter
Started by slayer007, March 28, 2010, 09:26:54 PM
slayer007
Yes the circuit will work fine without the capacitors and the extra diodes.
It will also work with just one of the two transistors eather one.I was just getting good results with the two but it will work with just one or two MPSA06's or viseversa.
The bottom of the towers I might have connected to a small antenna some times,But thats about it.
I just left a little extra wire at the top and bottom so I can connect the coil to what ever.You don't need to have that much at the top.
woopy
Excellent Slayer
But i am something confused about your transistor on the exiter . Because you said that you use a PNP transistor in your last set up.
But on your shematic it is a parallel of 2 NPN transistors.
Please can you give us the actual shematic, as it would be usefull to replicate your exact test.
At the present i use the 2N2222 A (single ) and get also very good results.  So i used the Tesla pancake bifilar (that  i made for the exiter )    as a receiver and i could get about 1 meter transmission. on 6 volts at about 200 ma.
The exiter has about 1 meter antenna at the end of the L1 coil  and the Pancake is about 1 meter away and can light dimly a led (AV arrangement) on a single wire the other wire of the coil is free (hanging in the air). On the pix you can see the distance between the antenna (red wire on the left) and the Pancake coil on the rigt with hanging lit led
Than i made a small loop detector to improve the probe detection of the scope and i could test the power of the antenna all along  (see scope trace at about 60 cm from the beginning of antenna)
Will soon try the 2 receivers coils and than cut off the exiter
Yep   very promising !
Laurent
slayer007
This is just a follow up to last nights video.
Lidmotor said the scope probe would affect the circuit.
He was right even when the power was turned off the probe was getting a small amout of AC from the AC ground.
In this video I have the probe and meter disconnected.The blue led's are still very dimly lighting, but not as near as bright as when the probe was connected.
So I guess there is nothing special here.
Here is the video.
http://www.youtube.com/watch?v=STbFYWITmLk
slayer007
Quote from: woopy on April 05, 2010, 05:11:07 PM
Excellent A
Laurent
Yes I still like to use MPSA06 transistors I was just using the old PNP for a test I was doing.
MorePowerEgor
Hi This is my first post.
I've been lurking around for a few months.
Take a look at this guy -
http://www.youtube.com/watch?v=Y-DjFZfTITk
There's 6 videos that make up the lecture, in which he runs a demo of an exciter.  He states that he has worked out and tested the theory of what's going on. Fits exactly with what's being seen in the Lidmotor and Gbluer videos.
Found it on a youtube channel - Miguelgot3
He's got 700+ uploads so I seached 'Tesla' and got a result.
The lecture seems to fill in so many gaps on lots of threads on this forum.
I've also posted a video on my youtube channel that might fill in a few gaps for some other threads.  Spread it around to those who might find it of use.
http://www.youtube.com/watch?v=9fNSoAsHz0I
Bit by bit the puzzle forms!
