XX. Perpetuum Mobile Clock - interesting clock
Started by FreeEnergy, July 04, 2005, 04:14:42 AM
Bruce_TPU
Quote from: Thaelin on April 11, 2010, 05:11:20 AM
   Pay close attention to the missing teeth on the
satellite gears.
Hehehe... Very good Thaelin.  Only one thing could have caused all of those missing teeth from substandard metal from that time period...
Airstriker
Well... A beautiful piece of art. But I don't think anything more. You don't find perpetual motion machines in the physics museum ;) Anyway, it must be incredibly fascinating to watch it spin ;) You can find other cool clocks under the following link: http://www.physics.uq.edu.au/physics_museum/clocks/
Some are pretty amazing, like this one:
http://www.physics.uq.edu.au/physics_museum/clocks/sky52.jpg
