Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
sparks
   I having been working electric motors and generators for 35years.  In a very old book probably 20years ago written by a variety of authors when electric motors were steadily replacing beasts of burden and waterwheels I found this explanation of how a dc motor works.  The magnetic field flows from left to right on the page.  The armature conductor flows in and out of the page.  And the magnetic field flows around the current carrying conductor.  You will note that the magnetic field created by the field winding or permanent magnets opposes the lines of force on the top of the conductor and reinforces them on the bottom.  This causes the conductor to move up the page as something flows from a high density magnetic field to a low density or cancelled magnetic field.  This causes the conductor to move and the dc motor runs.  (If a permanent magnet could be made that produced the same type of magnetic field as a current carrying conductor then a totaly permanent magnet motor is likely to provide a new energy scource)  Since on a dc motor the conductor leaves the field and then renters it traveling now against the  magnetic flow the magnetic current needs to be reversed in either the field or the armature.  Brushless motors change direction of the field magnetic current while commutated motors reverse the armature currents.  Hope it helps.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Bruce_TPU
Good evening to ALL,
I have completed my fifth and final (for now) Tesla Bifilar Pancake coil!  I will epoxy all but one of them, this week, because this weekend I want to play... lol, and see the difference pulsing the plain one, vs. the one with the iron oxide.  Also between the "standard" bifilar way of connecting and the "Marinoff" way of connecting (though he never used a pancake bifilar to my knowledge, I am excited to see if any difference!).  If it gives me HV from 3 or 4 volts, I have another idea for Sam's and my TPU build. ;-)  We need a HV transformer after the mixed signals are split and inverted.  More than one way to skin a cat!  (kinda gross saying, actually!  LOL)
I will then stack my pancakes, connect them and have them ready to be sandwiched between my giant future magnets.  That is where this build gets really expensive!  Perhaps I can make you guys some bifilar pancake coils and auction them off on Ebay to help fund the magnets?  I will need about $800.00 worth.  I am committed to this project, because I am not replicating anyone (not exactly) and I am using my own thinking.  I actually think this stands a good chance of being amazing.
In the picture I have placed a nickel for perspective of their size, underneath the center coil.  It is on the table.
Cheers,
Bruce
Airstriker
Hi Bruce,
Are you really sure you want to spent 800 bucks for a project that nobody is really sure will work ? I also have a project that I'm personally 100% will work but I'm a bit sceptical in investing 1000$ on it ;] Be aware of the difficulties in operating such big magnets - one mistake and you will throw them away ;] Also note, that if you let these magnets join by any chance, you wil have a big trouble with separating them. They are also quite dangerous ;/ Why not use a tiny model first ? If it's reall it will work also. I scaled my project by 1:10 and so did with the costs. If it works I can build a big one. If it doesn't - my wife won't be so angry at me ;)
sparks
another alternative would be to use electromagnets driven with a battery.  They pickup entire cars with big ones.
Think Legacy
Spread the Love
Bruce_TPU
Hey guys,
I appreciate the concern, but it is "just" money.  Worst case, and I end up selling a bunch of magnets on ebay.  I have spent so much money on OU research that has not worked, but I know this will produce power.  Will it be OU?  There is no way of knowing until I try.
Electromagnets require electricity.  Not the route to OU in my humble opinion for this build.  These magnets are powerful with seventy five pounds of holding force, each.  I have no intention of allowing them to come together.  But, if they do, I will have purchased a magnet seperator, from K & J Magnetics.
So, onward we go!  When I think of Marco, Giantkiller and Ironhead, who have spent considerable fortunes building, not to mention Moby, it is a drop in the bucket.
Cheers,
Bruce
