Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
SkyWatcher123
Hi Bruce, your a busy beaver over here it appears. Interesting setup you have got going here. Still putting together the pieces on that other project.
peace love light
Tyson
Bruce_TPU
Quote from: SkyWatcher123 on May 20, 2010, 06:45:18 PM
peace love light
Tyson
Oh yes!  LOL  This is my "expensive" build.  A little more long term.  Our project is inexpensive and giving me something to work on while I save for magnet money for this project.  I have "high hopes" for both projects.  I am very glad to have you building with me on the other.  I love to build and experiment.  Too many people just reading and never experimenting.
Cheers,
Bruce
Bruce_TPU
Good evening ALL,
This evening, the remaining holes were cut into the foam, for the smaller magnets that will be on the outer edge.  Each magnet is spaced the same exact distance from another.  I want a very uniform field.
1/2" magnets, will be along the edge.  12 of them per rotor.
Tomorrow I begin to machine out the inside of the magnet holders.
Cheers,
Bruce
Bruce_TPU
A Pleasant Saturday Evening to ALL,
I have completed the machining and sanding of the inner ridges on the magnet holders.  I have also cut them to their proper height.  I then glued each one into it's foam compartment.  The first rotor is complete, it is just awaiting more magnets.  It was a lot of work, but to protect $400.00 worth of magnets and myself, I think well worth it.   The magnets will not move, yet, they will have not been glued in.  Each one perfectly spaced with its neighbor.
Cheers,
Bruce
Bruce_TPU
Hello everyone,
I have placed the finishing touches on Rotor number one with some paint.  My last SSG3 device looked like such a contraption, that I am determined that this will look good, and hopefully exceed expectations when working.
Cheers,
Bruce
