Increasing magnetic fields for magnet motor
Started by gravityblock, February 14, 2009, 08:40:28 PM
gravityblock
Quote from: Judges on June 10, 2010, 03:22:44 PM
HELP,,,,this,,,,http://tinyurl.com/bg9ece,,,,keeps sending me to a coin buying site.
Really would like to see details.
Looking for a new project to start on,,,this MIGHT be it.
Joe in Texas
GB,,can you send the zip file to my email,,,joesmith@cvctx.com? or some other way????????
also,I will not miss-lead you.IF
I do not want to try building it,,Then I will state this.
I uploaded the images to this forum.  I had to scale them down slightly and had to make two separate uploads due to the 5mb file restriction size imposed by this site.  If you have problems with the below links, then please send me a PM and I will e-mail them to you.
increasingField01.png,  http://www.overunity.com/index.php?action=downloads;sa=downfile&id=385
increasingField02.zip,  http://www.overunity.com/index.php?action=downloads;sa=downfile&id=386
I've been thinking about giving this build a try also.
[Edit:]  Reply #14 of this thread has larger thumbnails that could give you a better idea for the build process while you wait for the files to be sent via e-mail if the above links don't work, http://www.overunity.com/index.php?topic=9139.msg240745#msg240745
GB
Judges
O.K.,,,,I have them now GB,,,,will be a day or so getting back to you.Health issues.I will try to give my thoughts then,.
God Willing,
Joe in Texas
Judges
Gravityblock,,,
I will try to replicate the Ring.
I got a very good start on my Magnet Maker,,,this is from  Magnet Magnetizer by David L Gingery,,clear plans,simple schematic,plus I have all the materials to wind the coils,One of the two alike is   halfway finished,,,he ask for cold roll iron,I will used laminate,the grain oriented,silicone steel type.
I am asking myself how I can cut a 4 X 8 chunk of laminate into a a 4 X 8 circular coil core,
He uses 18 gauge magnet wire,,I have 17,,mine is bigger.
The Geek group recently posted a video,,,blowing stuff up,,I
have quite a few electrolytic capacitors,,big uns,I want to follow their basic set up.
I also have a Fluke type Gauss Meter.2065783_A_w.pdf (application/pdf Object),,It will have a new battery and all the sensitivity I can coax out of this thing.
GB,
I will follow your layout for the ring,after I have built the magnets,,,I think the trick might be to have magnets in ascending,descending order of magnitude.
I am looking at a week,earliest,,,two weeks most.
We shall see.
Joe in Texas
Judges
Had almost finished one of the two coils needed,when I realized my coil form was to small.Will have start from scratch with Magnet Maker.
GB,,the spokes,,,,can they carry a linier actuator?,,to move the two end magnets?
Thanks,,still pondering your entire concept.I quoted you below
How do we get the wheel running from the North Pole to the South Pole on increasing magnetic fields to reverse itself at the bottom and allow it to continue without any assistance or breaking point.
END QUOTE can you give me this again perhaps in different words??
I should add,,although I stay logged in all the time (98%) I
visit this site usually 4-5 times a week.I just dont spend that
much time on the computer anymore(summertime perhaps?)
Joe in Texas
winding #17 Magnet Wire ain't really a piece of cake.I have seen #14 used in HOUSE wiring.
Judges
Comeing along with the magnet maker,,it will be heavy,copper around 60 lbs and steel core possibly 100lb,stayed with origional concept of book describing the building and operatin (on time 3 secound).
Two very heavy spools of copper with silicone steel laminate for
core.One spool almost finished,shooting for 22 layers of 46 turns
whicjh will give me 1012 turns.
The schematic had called for 1600 turns with #18,,I have a lot of #17,,slightly larger,also I will be have quite a few 'square inches if core,,,so I need to do some math,which I am slow and not very good at,would be good if someone who is, might help me later when I will need to know this.
Joe in Texas
GB you will be the FIRST person I will send free magnets to.
