The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
vrstud
That is how the diet coke and mentos trick works.  The mentos surface is actually very rough and is filled with little pits and valleys.  This gives it a very large surface area which allows for more of the carbon dioxide to form on its surface.  The same thing happens your straw when you put it in a cup of soda, only on a much lower scale.
oswaldonfire
That is correct vrstud. But we're looking at using extreme surface area to get rid of the gasses - not collect them.
How is this possible? Find the answer to my quote below:
You're both thinking MACROSCOPIC - we want MICROSCOPIC.
Can you think of a system in which the electrodes are so small, it will be nearly impossible to get power to them? I can.
Which has more surface area: a bucket of peas, a bucket of rice, or a bucket of granulated sugar? As the particle sizes decrease, surface area increases - an inverse relationship. What states that we must stop at the size of granulated sugar? Think smaller!
atlantex
oswaldonfire
Yes, you're getting there! This gives us a HUGE surface area, and there are very small particles dispersed within the water - the gasses are given off straight into solution.
Take a small block of, say, aluminum, with 6 square inches of surface area. Now grind it down into a VERY fine powder, and it has thousands and thousands of inches of surface area.
Now the question is, how do we provide electricity to these particles (our electrodes)?
atlantex
hold a blank end of copper cable into the mixture and see how the water becomes "dirty" :-)))
Well, the only way can be a electric or magnetic field, the positv side could be the container itself.
