Rosemary Ainslie COP>17 Circuit / A First Application on a Hot Water Cylinder
Started by Rosemary Ainslie, July 18, 2010, 10:42:04 AM
mscoffman
@Rosemary
Don’t listen to your critics.
High current pulses into acid/lead or liquid or gell batteries
causes cavitation bubbles in the batteries. These initiates D+D
cold fusion, which is where the extra energy is coming from.
period - end of story as far as I am concerned.
To improve your experiment make the MOSFET gate drive power
come directly from the unitary 24Volt power supply. Make the
oscillator a (data) signal rather then a power signal then use an
opto-isolator to amplify the oscillator signal for MOSFET gate
drive. Now the gate drive power all comes from the unitary
supply. Next split the special load up ½ between the source
and the other ½ on the drain of the MOSFET. Now any gate
drive power will find itself dissipated in either ½ or the other
of the special load.
Experiment (a): show overunity energy production just as usual.
Experiment (b): put a dual section high current LC pulse filter
between the unitary power source battery vs. the rest of the
circuit so that the pulses are fully averaged by the time they get
to the supply batteries. You should find that now, no power gain
is present in the circuit â€" the reason is the above. This will also
suggest to you what components will need to be present to make
the device function.
Good Luck!
:S:MarkSCoffman
powercat
Hi Rosemary  ;D
Great work i hope you get there this time  ;)
Here's a quick one,
Moon Landing Sketch  :D
http://www.youtube.com/watch?v=P6MOnehCOUw
cat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
Rosemary Ainslie
Quote from: powercat on July 24, 2010, 05:40:33 PM
Hi Rosemary  ;D
Here's a quick one,
cat
Hello CAT.  So nice to see you around.  And thanks for the link.  Hilarious and MUCH NEEDED.  I rather missed your touch here.    ;D
I also hope to make it this time round.  When I'm not fighting MIB's I get landed with jealous replicators.  And right now EF.com is pretty well controlled by both.  I hope to be a trend setter here by switching sides.  And excessively kind of Stefan to allow this.  But there's an enormous advantage to working from an accredited laboratory.  And even more so as it's a University - which means that the knowledge is intended for general benefit.  Our universities are still very much public property. And I'm an incurable optimist.  LOL
Kindest regards,
Rosie
Rosemary Ainslie
Quote from: mscoffman on July 24, 2010, 04:13:31 PM
Hello Mark.  I'm afraid I know virtually nothing about cold fusion so can't comment.  But I see that it's coming more and more into vogue.  I do have a schematic that I'll be posting later today - on an arrangement between lead acid and alkaline batteries which I think may represent a closed system.  I'm hoping Farrah will read here.  She may be able to get it to concept phase.
Regarding your proposed experiments.  Not sure that I followed it correctly.  We did run the switch from the supply battery if that's what you're recommending.  But we've never tested a filtered waveform.  My concern here is that aperiodic or parasitic Hartley number.  It's so easily snuffed.  I'd be concerned that a filter may do just this.  I just don't know enough about it.  But I'm satisfied that we will get to test this as Donovan has already included this in our proposed test procedures.  I believe he's writing the 'software' as required.
Thanks for the good wishes.  They're much needed and, believe me, much appreciated.
Kindest regards,
Rosemary
Rosemary Ainslie
Apologies.  I've just seen an error.  I need to redraw the schematic.  BRB
