0 Members and 45 Guests are viewing this topic.
do you like this topic?
 no, it is BS
david lambright
hi, my name is david lambright, and i have built something interesting. these devices are based on Leedskalnins PMH. i guess you could say the devices are perpetual radiators. my devices make a visible optical distortion, that mimics a heat type wave or mirage, with out any heat....there is much more that it does, but for now, i will focus on the visible effects....i have built a rotor, with 24 steel segments, on a bearing so that it can be spun....this device radiates a visible distortion and needs no motion, no batteries, only an initial charge from a battery, like EDs PMH.....i post at EF also, i started a thread "gravity waves found" there with lots of interest....i have also built a simpler device to show this "glimmer" effect as it is being called.....there are step by step videos on my utube, potatoheadists channel, how to build the rotor device...the next type of device uses iron oxide inside of an aluminum tube bent into a circle or toroid and energized....this device produces a "lensing" type effect...i am currently building these oxide core devices for testing by members of this forum...they are very simple to build ...i have 2 spots left if anyone else is interested.....david
Rosemary Ainslie
Dave, I missed this entirely.  I need to go out - but will check in later this pm and see if I can, at least, post some links.
Well done for this.  MUCH NEEDED.
Kindest regards
Rosie
IotaYodi
Quotethat mimics a heat
I dont remember you saying that in your original post. Need specifics on the build. Dont suppress it but spread it. A clear concise schematic can speed the research up much faster to see if its a viable project. If You have a video please give a link.
What I know I know!
Its what I don't know that's a problem!
Rosemary Ainslie
Hello Dave.  I've got 3 days of extensive work required on my thesis.  I won't be able to get back here until Saturday.  I'll at least post your video links.  But you need to engage here Dave.  That Lambright effect needs to be seen and understood.
Guys, for those of you who read here - the facts are this.  Dave has a rig that under certain conditions is able to show a 'glimmer' that is an entirely new effect - hitherto not recorded by science.  It is not the result of a Schlieren effect - of light reflecting against particles of dust or suchlike - but a unique 'glimmer' that is elusive yet entirely visible once one has 'trained the eye' so to speak.
The implications are that this may be a result of some kind of gravitational influence - precisely because it appears to 'bend' light.  But other strange effects are that it induces a magnetic response in material that is not traditionally known to have magnetic properties - string - rocks and such like.
I have myself tested this and while I do not get the light distortions I do get clear anomalous reactions with objects hung or placed in proximity.  My own rig was a variation of Dave's intended to test whether the 'Lambright Effect' related to the assymetry which was evident in his own rig.
In any event.  My time is wholly constrained for a few days.  Meanwhile here's a link and I would recommend that you look through the balance of the links there to better acquaint yourself with this effect.
And Dave, please post those new 'developments' that you've managed that people can understand it more fully.  I'll get back here on Saturday
Kindest regards,
Rosie
http://www.youtube.com/user/potatoheadist
david lambright
rose, thanks and well said...over at EF, alex posted that this glimmer effect is well known and nothing new....i am hoping to get links to any thing similar to what i see with these devices.....i have looked but have not found anything yet....if anyone finds anything at all similar to this "glimmer effect", please post a link.....rose thanks again....david
