do you like this topic?
 no, it is BS
david lambright
hi cletus...i do not mind if you post, i do like the way you put it all together, i think you have linked it.....rose, dont mind him, it is the gremlins we must keep an eye on, thanks for watching when i was busy/distracted...you are a friend!...i will be ready to send a OC device to you by monday, if you want...i checked at the post office and it will be only 4 or 5 dollars US to send it to you...i got that covered...i just wish brucetpu would send the device to matt...i mean that he wont stall this from moving forward, but it would improve the ride!....any way, i will post again tomorrow......david
david lambright
its tomorrow somewhere!..i had to answer smokeys post!...the laser...the one i used was a cheapy laser level...i moved the beam back and forth and up and down around the PMH ring, and it seemed that when the beam[laser] encountered the field[radiation]is when we would feel the pulse!...... i know it sounds odd, before i posted anything about this, i made sure that besides me at least 5 others felt/saw/experienced the effects i talk about on these forums.....even now, i sometimes have to "pinch" myself, by doing the tests again because it still is bizarre what this energy does!....i must post more videos next week on the oxide core devices and the effects....david
sm0ky2
it seems many have the same questions...
first i'll send everyone to HERE.
http://www.youtube.com/user/potatoheadist
he explains every detail of what and how its build.
next i'll give my interpretation of the critical components and open the door to an infinite number of possible variations that could be explored.
essentially you have a circular path for the magnetic current to flow around. AND appendages to the flux-domains, in the form of "C", "V", "U" shaped pieces. the idea is to split the poles by extending the flux-domains.
the grey ring in this particular set-up is imaginary, its formed by the back side of the pipes. but this gives a clear visual of the magnetic arrangement.
Rosemary Ainslie
sm0ky2
Quote from: david lambright on August 28, 2010, 03:12:52 AM
the laser...the one i used was a cheapy laser level...i moved the beam back and forth and up and down around the PMH ring, and it seemed that when the beam[laser] encountered the field[radiation]is when we would feel the pulse......
thanks.  thats very interesting stuff.
