Magnetic Separation of Water into Hydrogen and Oxygen.
Started by Hope, August 28, 2010, 08:27:38 PM
Hope
If you modify the magnetic plate separation technic to include other fluid mediums, we may learn to do this with the other matter types including water of course.
Low-Q
Can you explain this further? Pictures, links, etc?
Any free way to separate separate hydrogen and oxygen from water are welcome :)
Vidar
Hope
http://www.freepatentsonline.com/4261711.html this is the patent filed.    Using this and finding the +/- frequency or materials to filter thru should be about the same a nature does it.   This seems to be efficient beyond measure since the magnetic field is not effected by load.  It only places all objects within that field in polarity with this field.   I suppose building items will be positive fields and dismantling them will be negative.  THIS NOT THEORY!  This is only applying the same proven principle with specific fields chosen to most effect the wavelength components individually, thus H2O  Hydrogen being the more positive, Oxygen the negative.   The boundary to force these elements thru may just prove to be a strong neutral magnetic field with charge plates to assist in creating a flow path.  The charges on the plates may also have to be magnetic fields.
Edited by me.
Hope
WOW   looking at my own post and thinking about "many things are possible when the shape is round" (Tesla) and realizing this idea would best work in a sphere(s) ;  it would seem I just described how a moe cell model would work.  LOL   can this be true?   So what now do we call it a MAE CELL?
Hope
moderator pls wipe this topic   I will restart it with the CORRECT patent when i can find it again.  60 years now metal industry have been separating large metal plates by making magnetic fields pass thru them causing the metals to gain a like magnetic charge, then the metal plates repulse each other and separate (levitation).    But now i can not find that article.   I think Bruce has a motor design using this principle  but I can't look just now for it. (again)   Metal washers on a shaft moving past coils as the magnetic field separates the washers.    If the washers were stationary and charged with current could the magnetic field flux that charge? (and do it with VERY nominal power).
