do you like this topic?
 no, it is BS
Rosemary Ainslie
And guys, Jesus, all - just a small point.  Try and hang various types of material on a cotton thread over your rigs - those that have them.  I think you may find a curious 'magnetic' type response in just about everything that you put there.  Certainly that's been my experience off my modified versions of the rig.
In this result I see a direct correspondence to Hutchinson effect.  So.  There it is again.  It seems that if we are disturbing the natural justification of magnetic fields - inside material - and if this is then inducing an inappropriate response from the material - then that speaks to some kind of hidden magnetic field inside that material.  If the field was inside the atoms then I suspect that the atoms themselves would somehow become changed - but they don't.  Therefore, perhaps it's outside the atomic structure but is nonetheless able to vary the typical atomic or material response required by a smooth gravity field.
It's a dark mystery guys - maybe dark matter?  I think so anyway.
Rosemary
cletushowell
Rose can you try to type this where
others can understand
the light goes in the straight line down the middle
rose but see the bottom triangle in red
it goes to the second triangle above it but then prism
to the second triangle to those 5 lines
that five bounces in the star bending
between the six point but the thir triangle refocus them
to the fourth but when it reaches the fourth the light is still
there but its now -+ 120 positive neutral
not ++ 220 its the same amount of light
because the light is in the middle
the best i can define this rose is a flourescent
tube but i dont really know how those work
but i think theres a flat plate on each end
the light bounces and then another flat plate
the energy and polarrity of how it flourescents work im nit shure
thats my best explination guys we have the answer comunicating it is not my specialty maybey rose can help with this
Rosemary Ainslie
I think you've done a good job of explaining this yourself Cletus.  No need to improve on it.  I get it that you're showing the variations in the path that light would take in a varied magnetic field.
I think fluorescent lighting is best explained as a chemical interaction.  But I'm no expert Cletus.  I've been hard pressed to get my head around even the simple chemical interactions in your average lead acid battery.  We'd need a chemist on board to give an explanation here.  Perhaps Fritz?
Kindest as ever,
Rosie
cletushowell
I was telling dave your looking for somethhing
considered unknown but when whoever the consppiracy
crystal showed up from my hacked text it has a feather
attached i realized after carefull
examination of what exactly the would send the feather
its a static detetor finds energy you cant measure
i knoticed when i build energy i couldnt always read it with metter but i could
measure it with the feather just a tip
becarefull the static can due things you wouldnt dream of
like turn your arm into a ballon try not to hold a magnifyer
wash your arms good with water keeps radiation low
i also noticed if you gave a bad nerve like me
in my back that if one side of the body has more energy
then the other that nerve really hurts
jesus washed the feet its crossing both sides of the energy of the body
me im always messed up but thats cause one legs cut off the nerves
all screwed up got solve how that starfish regrows its limbs
Rosemary Ainslie
Cletus, I'm so sorry you have pain.  I think life's already hard.  To deal with actual physical pain as well?  That's too much.  I'll say prayers for you Cletus.  I'm not sure they get very far.  But at least it's a measure of some good will and that definitely helps.
Kindest regards,
Rosie
