do you like this topic?
 no, it is BS
nievesoliveras
Quote from: david lambright on September 02, 2010, 12:25:34 AM
hi jesus......just a thought....try holding a small neo magnet about 20-30mm from the device...reverse the magnet till you feel a slight repelling between the two.....observe while you are feeling that...try and keep the magnet pushing against the rings field......or try using a piece of quartz crystal near the device.....this also seems to help....david
I holded a magnet as you said, but when I turn it around it does not repel, it also attracts the ring.
Maybe I damaged the device when I gave it a 12v strike.
Specifically I took both coil ends and placed one on the negative and holded it there, then I touched the other end to the positive.  A blue spark formed and that was it.
Jesus
sm0ky2
Quote from: nievesoliveras on September 02, 2010, 06:21:42 AM
Jesus
@ Jesus
  Watch these two videos. and become familiar with this concept
im not sure what this thing looks like what he sent you
but they all work in the same way.
its a magnetic "loop".
first one is random PMH from YouTube
http://www.youtube.com/watch?v=qHkcJ0rCIXQ
This is Dave's.
http://www.youtube.com/user/potatoheadist#p/f/10/S3ufPsu6AJU
cletushowell
Hope you are the closets
the reason is stick to the 12
or go 1.2 would be the exact center
sorry i do so much every day im like
the supper computer one pop up sguts me down
data storage is limited,
ok 1.2 is the center
2 =+
.=nuetral
1= - but negativs is not negative
       It one so nuetral is not nuetral
       Its 3 in 1
2+1=3
2-1=1 if your not religious
think of it this way the smartest men in
the world translated the bible they added so much
science to it its insane just no one understands
there all stuck in doctrin debates davinci
used the numbers for his code
because numbers dont change in translation.
Anyways where was i undertanding
your dc going to your i notciced i can discharge a rock
by spin from a antenna others noticed the plate above
magnets he deserves credit i dont know his name
he was on antigravity youtube before i got banned
but i we made a ac battery we would
be spinning the flywheel and storing energy in a spring
but spring maxes out pretty fast but it would spin back and make ac
energy again now if you think about this string it
is like a spring but can hold many winds
or twist this is the key to the battery
if we can store the energy in say daves device
and or a rock and some how develop a theory in electricity that
over lays energy like twisting that string
it can charge discharge magnets hold energy a long time
i made a electromagnetic feild from
the antenna and salt wiped everything
including my nice 60,000 dollar prosteic computer
chip i did have insurance well thats a different topic these are the pop ups that shut the computer down.
My mood swings are determined a lot by pain
too if its been a long day I can be irritable expecialy when
something gets lost like how i lifted that cup
or the 12 salt battery or overlimit contiual ac
or the tuning or the light bulb frequency i had perfect
all these once lost are like throwing the ball from half court
watching it go in then trying to tell your friends they say ya right do it again
well maybee if i throw the ball enough times but its like hitting the loto
if i can recreate it to demonstrate
some i do figure out how but your
string phenomenom is not just a string
ok I charged a light bulb with a magnifer
when i created feild a and feild b
from the photovalic effect that wapred the light bulb
but before i warped the light bulb I did mv
testing to prove it there was energy from the
light to the feilds on the bulb i knoticed energy go up
as heat energy go down as it cooled but a max effect or amount of change
before it stoped i think it has to do with the
amount the bulb can store heres a link to the warping the light bulb video its kinda shity feel free to recreate it and put it back out better
my video skills suck
i dont know why this doesnt get huge attention
its like one the biggest breakthru in science
direct drive propulsion and its not just light its frequency
nievesoliveras
@smoky2
I saw the videos.
I took the device (that it is something completeley different from both videos) placed a compass in the middle as on the @lambright video and gave it a 12v volt spark repeately until the compass changed position.
I tied it on a string as the graphic shows and the energy can be seen if it is at an angle with the window and you are about three paces from it.
If you get closer, you cant see anything but if you place the compass under the device, the compass needle begins to vibrate up and down.
Jesus
