do you like this topic?
 no, it is BS
sm0ky2
@ Jesus
We should look more into this "vibration".
if we can figure out which direction the motion is, then put a coil perpendicular to generate electricity.
"Zero Point Module"
i keep thinking of crystals, to resonate with the ring.....
like the ones SuperMan had,  long, with diamond-ends, perfect crystaline structure.
tuned perfectly for the device, so they sing in chorus.
cletushowell
Im so happy for you i wish my dad would take five minutes to
see my stuff every one my family
just dont care i just did gravity and antigravity
got it to lift and drop with the power switch on and off
if the the ion propulsion
tesla tower light bulb turbins it can basicaly do anything
no one gives a shit im banned from antigravity
my internets shut off i guess the neighbors
no longer works so i cant even share it with a couple people who do
watch my videos on youtube i guess ill go to bed
you know why tesla tower was not done
he was going to put the optics in each
level basicaly all the magnifyer glass on top
would be the crystal the optics would be seperated by the
gases like flourescent and changing optics changes frequency it basicaly would charged earth with magnification
and seperating the frequency from uvc
it was not going to be wireless it was going to be earth
earth is a polished crystal he was just tunning it
to operate at the power level we needed
dllabarre
Quote from: david lambright on August 30, 2010, 06:26:21 AM
hi everyone...jesus, your device might come today!.....jetijs, yours wii be there soon...guys, when you get the device, dont expect it to shoot green sparks, lol....just look at it, i have found if there more people looking at the device, the ones who see it right off can help by their description of what they see....hold it up, turn it slowly, do not try too hard, kindof let yuor eyes relax....the words people are using to describe this....looks like heat, a bubble or film, and like a lens...take your time, it will manifest...also my newest device!!...i made the ferro fluid core device using a clear vinyl tube, about 2" diameter.... the tube is 1/4" vinyl, coupled with a short piece of just larger tube....i filled the tube with ferro fluid, not very easy, wear gloves, it was messy but worth it....i could not get all the air out, i left a 1mm bubble in it...i do not think is affects the orbital path....20 or 30 wraps of copper wire and energized first one way, then flip the battery and do it again.....very quick, so that the wires do not get hot.....this device really does the lens thing good...is is just as smokey2 said, you gotta see it for yourself.....david
Hi
I'd like to get one of these devices.
What do I have to do or where do I go to get one?
DonL
Rosemary Ainslie
Quote from: Hope on September 02, 2010, 03:53:27 AM
Would it stand to reason that if the PMH can magnetize non ferrous then it possibly magnetize light as well? Between any two different poles there would seem to me to exist a barrier or neutral, zero area even when a magnet is barred the barrier is still there but only very close or what do you all think? Else there would be no pole differences?? So Rosemary your exactly correct when you said NOTHING else would.   Neutral fields are so strong they even can separate poles when they are very thin.  Correct? Now that may be another key.
Golly Hope - these are difficult questions.  The thing about photons is that they are classically considered to be neutral - having no particular justification.  But it also seems that our visibility range is restricted to precisely that frequency that results from an interaction of that photon with physical material.  It then defines that material and 'shows up' its colour.  But I don't think there's that much known about the particle itself.  This, because it has no 'rest state'.  And it's hard to track light speed with our eyes.  Especially mine.  LOL.
So.  Back to your question.  I don't think that photons can be 'magnetised' in the sense that one can magnetise a coil, or physical material.  But what I do suggest is this.  We know that our earth has a magnetic field and, by and large, it's smooth.  Sort of consistent with what is described as 'Faraday's Lines of Force'.  But the reason I think we can detect this force is PRECISELY because we only see one half of that orbit.  We know of the force from the North Pole to the South Pole.  We have NO idea what goes on when it disappears back into the earth to complete its orbit - IF that's what it's doing.  In effect everything on earth has only EVER known one half of that orbit - again - IF indeed it's orbiting.  It's sort of like a 'voltage imbalance'.  It can be measured and detected.  What I'm trying to point to is that if we could experience the 'hidden half' of the orbit - inside the field - then we would have some considerable difficulty in distinguishing a north pole from a south.  But we also know that the vacuum of space has NO evident north or south justification or poles or charge differences.
So.  I'm proposing that the vacuum of space is just a great big magnetic torus.  A kind of moving scaffold.  But we DON'T see a distinct North  or  South pole or any justification.  This is because, if this great big magnetic field was there - and provided it was shaped like a torus which is just a really smooth and perfect magnetic field - then we would never know it was there and we would never be able to isolate any part of it as having any particular 'charge'.  If you put your probes anywhere inside the vacuum of space there would not ZERO volts.  NO charge.  And NO north/south.  This because every part of the field would be connected to every other part.  Unlike the fields of the earth one half of the orbit is NOT isolated from the other other half.
Now.  What I think happens is this.  Photons are able to move through those vast fields of space at light speed and by interacting with those fields.  The fields are smooth - the photon's follow the fields - therefore they 'find' the straight line in those fields and they forge their path through space.  The same when it get's to our earth's fields.  But when it hits Dave's rig - then these same magnetic fields are so crooked and distorted - that they simply can't find that straight path.  So for a brief moment they 'glimmer' and then move on.  And it's that Lambright Glimmer that we're seeing in his videos and - for those who have been privileged to see this - directly off his rig.
Which is my take.  Hope that's understandable.
Kindest as ever,
Rosie
david lambright
rose...sorry about the delay....i will fill the devices with oxide after this post, and mail them tomorrow....and don l......i dont want to make/sell these devices for money, i encourage everyone to build themselves, so you know exactly what it is, and the hands-on is just good!..but heres the thing...i ran out of tubing, so if you can wait a bit, i will build you one...will you show it to as many people as are interested?...and cletus, i have a device with your name on it !!i must say your brilliance shadows me, i think i said that right, anyway, you are awesome!...i will build you one when i get my next bit of tubing........thank you all...david
