do you like this topic?
 no, it is BS
Rosemary Ainslie
Quote from: david lambright on September 03, 2010, 02:17:55 AM
rose...sorry about the delay....i will fill the devices with oxide after this post, and mail them tomorrow....and don l......i dont want to make/sell these devices for money, i encourage everyone to build themselves, so you know exactly what it is, and the hands-on is just good!..but heres the thing...i ran out of tubing, so if you can wait a bit, i will build you one...will you show it to as many people as are interested?...and cletus, i have a device with your name on it !!i must say your brilliance shadows me, i think i said that right, anyway, you are awesome!...i will build you one when i get my next bit of tubing........thank you all...david
Many thanks Dave.  I suspect these donations of yours are impoverishing you.  They're very much appreciated - I'm sure.  And this, more than anything speaks to your commitment in showing this effect.  It's you that's awesome David.  And I'm sure we all realise this.
Kindest regards,
Rosie
sparks
    For some reason this device brings to mind the aharanov-bohm effect.  I may be mistaken but it is an example of the condition of space effecting the motion of wavepackets photons whatever.  Gravity bends light.   Each point in space at any given time exhibits some degree of gravity.  That same point in space also at any given time exhibits some degree of radiance.  The two forces are the only two forces.  All the rest of the weak neuclear and strong neuclear and electromagnetic forces are derived from these essential forces.  They are truely essential for if only one of them existed the ism would be the aint.  How long would a Universe exist that was totally radiant.  How long would a Universe exist that was totally attractive.   And here we are little inertia beings pretty mutch stuck in the middle between two clashing forces.  The forces of light and dark.  The yid the yang.  Chaos order.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
dllabarre
and don l......i dont want to make/sell these devices for money, i encourage everyone to build themselves, so you know exactly what it is, and the hands-on is just good!..but heres the thing...i ran out of tubing, so if you can wait a bit, i will build you one...will you show it to as many people as are interested?..........thank you all...david
I will definitely show it to everyone I can.
This is amazing.
Thank you
DonL
void109
While following this thread, I took a ring of steel, and wrapped three windings of coil on it at three locations.  I was just suspect that the ring didnt have to necessarilly be made of seperated or disjointed pieces.
I pulsed it from a 12v battery, shorting it against the coils in parallel.  I also just left it connected for durations up to 1s.  I havent been able to see any visual effect, or any sensory phenomenon holding objects near it.
I did find that if I hang it from a string with no torsion on it, it will accelerate up until the string has enough counter torsion, then unwind until resting, with the string having remnant torsion on it (you can see the string twist when I lift the ring at the end), so it appears to be prone to spin when hanging.  Have to test this many more times with several variations to be sure.  Here's the boring video of it:
http://www.youtube.com/watch?v=Yilx2r_9KAg
I actually live in Washington, and was thinking about driving down to see your device David. :)  I have an HD camera that can record at 1080p, and thought I might be able to capture what you're seeing on video.
void109
Almost forgot, I also took 5 1" diameter ferrite cores and cut them in half with a diamond wheel.  I arranged the remaining 10 half circles in the typical arrangement, wrapped coil around one of them and pulsed it to see if I could get it to lock.
No dice, they would forcefully join during the pulse, but completely released afterward every time.
I also made a PMH with a U shaped threaded bolt from home depot, and put a 0.5" x 4" steel bar across it and locked it.  Then placed it in water as I've seen others do and froze it.  I didn't see any anomalies as others had.  The PMH effect was there to be sure.
Do you think it is just the case that when we pulse the PMH it is aligning all of the atomic dipoles, and once oriented, they hold each other in place?  Then when you quickly remove the bar, it is just the dipoles 'relaxing', or spinning to a rest orientation, and its this relaxation that is inducing current in a pickup coil?  While this wouldn't explain any of the effects being discussed here, in this description there isnt anything 'flowing' around the flux path, it would just be the dipoles locked in place.
