do you like this topic?
 no, it is BS
cletushowell
Well dont feel out place your over my head and i juust built a jet from aluminum cans why do i only get the real
complex shit like sparks explains to me  what is pmh
Rosemary Ainslie
Quote from: cletushowell on September 07, 2010, 12:25:11 AM
Hi Cletus - I agree with you.  It's a rare thing to have such a careful experimentalist and always appreciated.
I think a pmh is a permanent magnet holder.  It's Leedskalnin's 'u' shaped magnet with a holder.
Kindest regards,
Rosie
;D
sm0ky2
@ Loner
When you have a 'magnet', its oscillating at a certain freqneucy, based on the frequency of the ferrite, and the strength of the magnetic field.
When you induce magnetism into a piece of metal, the field orients in response to the field of the ferrite.
When the metal is sustaining its own field (with no magnet)
it oscillates at a different frequency.
About the turns of wire::  if you use a thick wire you can do it with less turns,
at 600v, you dont need a lot of turns, even with a thinner wire
but thin wire with 12v battery, you need to increase the resistance, so you get more B-field than Heat.
if that makes any sense..
Low-Q
I haven't followed this thread very carefully, but I was reading "frequency" and "magnetism". So I will suggest you use litz wire to convert high frequency current into magnetism... Single wires suffer from the skin effect at high frequencies. So many thin and separately insulated wires might be a better choise?
Just a though from thin air :)
Vidar
cletushowell
@sparks i think thats why my jet worked so good i changed the metals to match i assumed the frequency of the copper snd frequency of aluminum
were different hutchesion sais when two energies fight
in the neusleus over the same energy then
thats what the power factor is in the neucletus
so if the energy from the inside matches the energy on the outside the north chases the south so is magnetism simple changing the outer electrons and neutron to equal the neucleus creating any other object to becom
the proton and electron so a magnet is the neuclues
does this make sense
