do you like this topic?
 no, it is BS
sm0ky2
@ Low-Q
will this "litz wire" perform the conversion in reverse?
turning high-frquency magnetism, into Current?
if so,. then dave should perhaps use this in his tubes??
@ Cletus
Now you got it.  And thats how magnetism manifests itself as
physical matter.
cletushowell
So beings i did
gravity= frequency magnetism temparture
ill now do
magnetism = neucleus energy matches outer electron and proton
And ill do being broke sucks
So all life has magnetic feilds a magnet
those feilds are magnified by flowing in a diection
of north and south but if the north is receiving
energy the sout is giving energy
the only way then to discharge a magnet it to
short the two energies or enter them into feilds equal
which is not impossible but dam near
so now we understand the magnet is the concentrated
energy and the free flowing of energy all the time
that can never stop all we have to do is learn to use the feild
better i beleive the ion propulsion thread
i did is the best start to understanding this
and then unserstanding when you
take energy from the what did sparks say
- entrophy the - side of the magnet the positive side gets stronger
so if we can ubderstand what will continualy
take the negative introphy say maybey water
then the positive will continue to pull
electrons or protons and those can go thru the
tube like sparks was explaining line up
to be used as light or power before tgey reach
the magnet then it will go thru the magnet to the
negative ibtrophy this is why moray sometimes used his
battery to start the flow of the negative entrophy
i hope im right I think I am and I pray you understand
because I can build all this on my own
cletushowell
Maybee daves device is a type of magnetic amplifyer
not in a sense of magnifying the magnetism
but in a sense of controlling the flow a reverse
generator instid of pumping frequency thru a wire to
create energy it would do the opposite pump frequency out of the magnet
creating the negative entrophy i think we really have the answer
if that device can countinualy pump the energy out of the magnet back to air
the magnet will continualy pull more energy can that device do that
if it can thats like amazing does it have to spin
or can it pull energy stationary
if its sweet sixteen I see why its pumping the 8
so its pumping all energy from anything making it a magnet
to absorb more energy so that thing is like a black hole
the light glimmer must not come from the device but from
the air energy around it being absorbed to it
man this is really cool
cletushowell
Mann im like on a roll this morning so
the water can take the negative entrophy
to a point it becones a magnet because the aluminum
disolves is the water seperating the
specific gravity negative entrophy
of the aluminum but then the aluminum
then adds to the water the water becomes a magnetic plasma
at which point the aluminum no longer wants to disolve but then
expel the jet the only way the energy can flow is in thru direction
or steam but the steam stoped in one test after boiling point turning a contiual gas but not evaporating at that point if more water is added
it absorbes more energy to steam so
i think the water can be used as negative entrophy till it builds the oxidization
to become magnetic fluid it then becones the neucleus the steam is repelled like the magnetic poles the condensed water
can be added back to increase the negative entrophy
because by condensing its lost energy to air
then it is added back it pulls more energy
by increasing the negative entrophy
and evaporates again so its can be used as a continual
negative but how to add it to daves device
im not shure seems like it would be the same thing in reverse
taking the energy from air makes the
steam evaporate on its own that sounds like the process
but doing it at a pace that boils the water
cletushowell
I think were missing a part we dont see
during the removal of energy from steam back to water
there would be a snow flake but because the tempurature
is warm the fourth season is so short its like it never happened
hot water steam snow cold water
we dont see the snow thats the answer
some how daves device would extend the fouth season
sorry i feel lost but i know im right let me think
about this its because it backwards
its hard to think backwards
ok i got it
daves device would not create steam
in the water it would run like a joe cell
cooler its not pushibg electrons into the water but removing them
this makes tge ice the energy is then removed from the air the till the point the ice melts it turns to steam on its own and recircles to the
atmosohere and if its in a relative warm inviroment this does not ever turn to ice but a cool running joe cell car
