Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
ramset
Grumpy,
I salute you sir!!
You truly are a man of good intentions and integrity!!
Chetkremens@gmail.com
Thanks Grandma
quarktoo
Signma16,
I had a look at that design you put forth here:
http://www.overunity.com/index.php?topic=4297.0
A quote from the well written post stated "The frequency should be a harmonic of the NMR of iron"
Nuclear magnetic resonate frequency of iron is 21.5 MHZ. Notice how Stiffler got an energy peak at 10.5 MHZ on his cold electricity claim? Notice how he didn't test above that frequency? He surely had the equipment to do it...
When TheBuzz pointed out the NMR harmonic, all hell broke loose and Stiffler took a hike. When I use the term "safe free energy device" I am always talking about NMR frequency of iron.
You can listen to the NMR freq. of iron on a police scanner at 21.5 MHZ and it is the reason that not much occupies that part of the RF spectrum. I point that out since a cheap scanner can be used as a piece of test equipment.
Once NMR has been achieved, the iron emits BETA particles which is mass being splattered from the core which draws more current into the coil to fill the vacuum. Use safety glasses to shield your eyes from the BETA if you enjoy having the long term vision.
A shorted coil will act somewhat like a spark gap in accelerating particles. It is really just the sharp swing of high low of a spark gag producing acceleration verses the magnet compression / acceleration of a shorted coil producing a reflected wave blast. So one could make the argument that spark gap is full wave at light speed verses the mag compression at magnetic saturation speed.
If you couple that shorted coil with a magnet, you can achieve a higher output since the magnet acts like a spring that is fixed at one point. The shorted coil is the anchor.
With very little modification, Stiffler's loopstick antenna design can go OU. But why didn't he do that? Probably because he was using multiple usernames and IP's to quietly get peoples names and addresses in the free energy movement. What did they gain for giving him that info? Nothing.
quarktoo
I should add to that that FE56 (common iron) will give up two electrons at NMR frequency transmuting it to FE 54 which is radioactive. You can look that up on some periodic element tables to verify.
If you go to
http://www.ccmr.cornell.edu/education/ask/index.html?quid=734
You will read that "We detect Hydrogen atoms by exciting them at their resonant frequency of 42,580,000 Hz."
Odd how it is almost exactly twice the NMR of FE56 huh?
Maybe the exact NMR frequency of pure iron is 21.29 MHZ instead of 21.5 MHZ?
Magneticitist
well unless im looking at the wrong place that schematic does use a spark gap.
sigma16
Quote from: quarktoo on September 12, 2010, 04:37:15 PM
Signma16,
Then 21.5 MHz must also be a harmonic of the pulsation of the universe.
Note that the device is called tetrahedral but he says the the lower three coils are at 30 degrees - so not a true tetrahedron.  The collector located where the fields intersect - the region of the outer areas of the coils. Lay out on paper and it is a parallelogram region.
So, you gonna get a piece of this?
