Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
Rosemary Ainslie
Quote from: gauschor on September 12, 2010, 05:19:29 PM
That's why I call it "amateur faraday cage". I should have added that for best results with the amatuer box one should go outside into the open empty country and then check the device. You can't do much more without getting it too costly. At least a considerable part of interferences will be stopped this way. But as it is now even the electric distribution boards in lasersabres room can easily collect hundreds of milliVolts. I can do myself with a simple wire, why should it be different in lasersabres room? You'll certainly understand that this is a problem when needing to evaluate the results and that any results can easily misinterpreted. Thus my suggestion with the amateur box, which shouldn't be too costly.
Then do the tests and tell us the results please.
powercat
Here is a post from jeanna on the : Nathan Stubblefield Earth battery/Self Generating Induction Coil Replications thread
http://www.overunity.com/index.php?topic=3500.msg256786#new
Hi everybody,
Lidmotor just pm'd me this link to someone in spain who has made a lasersaber stubblefield with the addition of a capacitor. I tried the cap once and found that the metal seemed to last.
I still do not have a working unit myself, but this guy does.
Have a look.
http://www.youtube.com/watch?v=XihmGdDpB2o
http://www.youtube.com/watch?v=4heZ0_rYdvg
jeanna
End quote
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
gauschor
@Rosemary:
I have not built the NS coils, because of the simple fact that I can pickup hundreds of mV in my own experimentation room with a pair of cables 3 meter length. I don't even need to wind them up nicely. I am highly assuming that the same happens with the proposed NS coils of lasersabre. If he claims, that it isn't the case, and his power comes from somewhere else, it is his job, to prove it or at least try to eliminate the most disturbing factors. Understood?
Rosemary Ainslie
Quote from: gauschor on September 12, 2010, 05:35:53 PM
@Rosemary:
I have not built the NS coils, because of the simple fact that I can pickup hundreds of mV in my own experimentation room with a pair of cables 3 meter length. I don't even need to wind them up nicely. I am highly assuming that the same happens with the proposed NS coils of lasersabre. If he claims, that it isn't the case, and his power comes from somewhere else, it is his job, to prove it. Understood?
@ grauchor
Indeed.  IF he claimed anything at all.  He does not.  He simply points at the experiment and shows us what's happening.   Perhaps you and Omnibus could return the favour and follow that good example.
Rosemary
edited.
Pirate88179
@Rosemary:
I said it before and I will say it one more time.
There were NO radio stations at that time anywhere nor POWER GRIDS in Stubblefield's area of the country when he was doing his work.  So why, if someone is replicating his work and his results, does a Faraday cage become the most important focus?
Stubblefield's devices are documented to have worked back then.  Many folks, including myself, have built them and they work.  Now Lasersaber takes it to the next level and suddenly, it must only work due to rf ?
One more time....there was NO RF back in Stubblefield's day which is why he is known as the father of RADIO.  It did not exist before him.  Does this make sense now?
Bill
