do you like this topic?
 no, it is BS
nievesoliveras
Quote from: truthbeknown on September 14, 2010, 09:23:33 AM
David posted last Thursday on this forum and another forum....This thread is getting cluttered.
J. :'(
This thread has been Astroturfed!
http://en.wikipedia.org/wiki/Astroturfing
cletushowell
Dude I dont know what your problem is
this is daves system when you cut the pipe depending on
where you cut it depends on what number out the pattern your taking
out if you cut exact midfle you removing
369 which goes directly between
9 between 54 to the center bounced back in diferent frequency
a 54
a 6 cut goes thru the two side of the pipe
not cut those are 11,10 or 12 there the same
a 3 goes thru 78
my guess is you dont understand teslas 369
or 333 or eds18 or the myans and so you also dont understand how
my pattern is perfect and is not a magical trick
but whatever dude I already told dave putting the math out was like putting my head on a choping block probly should just keep it faith is beleiving theres a force of energy between the cuts in the pipe the radiant
glimmer im done
cletushowell
1 loop is one pipe it does not defy your base 10 system in fact it
defines how your base 10 system works
how to cells of a honey comb share 1
side add any number between the circles you
see there the exact same thats why i drew the lines I would have connected the circles but my program does not allow me to do that when you see the patterns perfect you can see how one honey comb is surround
by more because the lines in the middle are the same
MrMag
Quote from: cletushowell on September 14, 2010, 02:43:18 PM
I think a lot of people here would of preferred the chopping block.
cletushowell
Good you got it chop the block in half any number is your
block you get the rest the patern in each half
congrats put them back together get your original number
