do you like this topic?
 no, it is BS
david lambright
hi everyone...question;....who all did i promise to build the oxide core devices for?....rose and cletus i know for sure but with all the excitement around here, i kind of lost track....anyway...please let me know.....david
david lambright
    As we can see from Dr. Dmitriev’s research, there is clearly an interface between the inner processes of the Earth, the outer atmosphere and the energetics from the Sun that is responsible for natural self-luminous formations and tornadoes. In the course of his research, Dmitriev also reports on various magnetic anomalies on the Earth’s surface that support this idea. On January 25, 2001, the Oregon Vortex, which is the United States’ most popular area for anomalies of this type, was again thrust into popular view when Nick Nelson appeared on the “Coast to Coast” show, then hosted by Dr. Mike Siegel. Mr. Nelson has served as a tour guide to this vortex since 1999, is the author of a book entitled “The Golden Vortex,” and currently has a website at http://www.athenapolis.com/NickNelson.htm.
    The Oregon vortex is spherical in shape. This conforms perfectly to what we would expect of a “vacuum domain.”
    The center of the vortex has a chimney-like movement of energy which lifts into the air. This shows that the field is actually a spherical torus, and it possesses a faster energy movement through its central axis than it does in the other areas, as we would expect.
    The energy in certain areas has spiraling qualities. In a certain spot, a magnetized pendulum will spiral in circles, and if a person tries to stand in this area, their body will naturally be compelled to sway in circles as well. And we already have seen the importance of rotation in the polarized CU.
    The vortex exhibits very strong electromagnetic effects. Movie cameras are not permitted in the House of Mystery (the name of the site built on the vortex,) ostensibly because the intense electromagnetic energies can cause permanent damage to sensitive equipment.
    Clear, anomalous changes in gravity are seen in the vortex. In one area, a circle is drawn on the ground, and the closer you get to the circle the more you will be forced to lean, at about 7 degrees of arc off of true perpendicular. If you try to stand up straight, you will fall over. In another area, a broom can be stood up on its edge and remain standing for up to 36 hours. At another spot, a ball can be released on a slide and “roll uphill.” All of these facts perfectly conform to the idea that a polarized CU causes noticeable distortions in the field of gravity, by altering the natural gravity-levity balance.
    The vortex possesses clear magnetic sheets of demarcation. We have already seen this observation of “spheres within spheres” in action with the tornado phenomenon as well as in Roschin and Godin’s replication of the Searl Effect in the laboratory.
    The center of the sphere of energy is in the Earth. This correlates very well with our expectations that these energy processes can be created by areas under the Earth’s surface where the fluid like material of the lithosphere is flowing rapidly in a vortex-like fashion. A more detailed study of the underground geology in this area should reveal such a current.
    The size of objects actually changes from one area to another inside the vortex. This is clearly visible to eyewitness observers and in photographs. Two men of equal height can walk to two different areas in the vortex, and depending on where they stand, one will clearly seem to be taller and the other clearly shorter. If they switch their positions, each spot will still show the same effects on their respective heights, so that the short man is now the tall man and vice versa. Again, this conforms with our observations from tornado phenomena that suggest that definite effects on matter are being produced, which can change its overall structure in heretofore-unknown ways.
    The changing size of objects cannot be measured with instruments. This is simply due to the fact that the measuring instruments also change in size as they move through these areas. Thus, “all is relative” within the vortex which makes accurate measurements of the changes impossible, except by visual observation..................hi everyone...all of the things that the oregon vortex does, my devices seem to do also....david
david lambright
zapnic
Quote from: david lambright on September 16, 2010, 01:05:40 AM
hey dude
here is the book http://books.google.com/books?id=xAOfLVoyCLIC&pg=PP1&dq=nick+nelson&sig=ACfU3U0u_aGdGFwjP9eKbcd4ItBqMrM-9A#v=onepage&q&f=false
and here is old thread http://www.overunity.com/index.php?topic=5445.msg123054#msg123054
thanks david you are making good work
bye
cletushowell
@dave
when I created the vortex I calculated it at 1.7 miles
I would spin and slam against the wall
in my dreams every night like 5 times as I fell asleep
till the subcountious matched the awake state energy
some how it created a energy vortex between
sleep and awake I dont know how to explain that
we did have problems with people swaying
on the porch mainly my cousin whos quite large
I was able to stop the vortex by disasembling
the moray valve that was funneling energy to the ground
rod wich was the water pipe after removing
the antenna the vortex continued to funnel thru the ground rod
it no longer needed the antenna or cells
I got pretty woried and did not know if I could stop it
I was wiping all the electronic stuff
the magnetic field was so strong in
the cable from the cell to the antenna was like the giant elevtromagnet
I did notice a vortex which have not noticed since
every day all the toilet papper rolls I set around the tub
would be in the tub by the end of the day
I woukd set them back on the edge and they would fall back in
within a day or so The water pipe I was using was next to my tub
and It did finally stop by soaking the entire property with water
for a good amount of time like 2 weeks
or so I was quite releived I could sleep again
and havent put the cells back together since
I did do some simple test of connecting
the magnet poles like that email I sent you
and I found I you put a third small magnet
between the broken ends that repel you can get the energy flowing thru the magnet and the third magnet can be remove it apears the speed at which
you remove the third magnet determines whether the ends begin to repel or
attract my magnets are not smooth and
the washer between may be  better then the third magnet
basicaly i touch the repelling broken half of the circle
together on the bottom put the magnet between the top
let the field start flowing thru the circle
and remove the magnet in the middle the reppeling force is the almost completly gone and actualy i got it to stick
a couple times but not exactly center then
because its not perfect the little offset seems to allow the
reppeling field to build again so it seems you can control the glimmer by
inserting a third field between it I guess two magnets would
be a 69=15=6  three makes a 369=18 =9
ill have to look at the number pattern but the
theory is right these numbers here may not be
i think its actualy a 55 44 ill see if I can explain that in numbers
seems almost like a third matrix is the broken
polarity the field created when magnet shears the
the invisible field that may take a while for me to understand
well hope everyone has a Good day Im pretty shure I understand the Joe cell now which was my goal hopefully I can build one as soon As I get some money together
