Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
hidave
Quote from: broli on November 13, 2010, 11:20:40 AM
hidave I think in your excitement your post on the previous page got very confusion. I suggest you draw your stepwise setup rather than describe it with words. Anyway thanks for the diy cap explanation.
Edit: I attached a drawing of your supposed fast charger, can you tell if that's all it is?
Edit2: Corrected polarity.
CORRECT!!!
hidave
Quote from: broli on November 13, 2010, 12:16:52 PM
I assume you confirmed that this is true usable charge that can give as much (or more) joule energy as when it was conventionally charged?
currently draining a charged battery with LED. Will let rest 24 hrs and recharge as requested by  ibpointless2
battery is very cold to the touch, these are regular alkaline batteries.
I'll do a controlled test later and post the joules data, or perhaps someone can do it?
e2matrix
I just did a quick and dirty test on a 9 volt battery that has been sitting a couple days.  Start was 9.09 volts.  Hooked up a 330 uf electrolytic same as my diagram - no diode.  Voltage went down to 9.08 volts.  Didn't see any rise after a few minutes.  No time to check further right now but as I was saying I'm concerned about alkaline self recovery in this situation.  My quick test is not conclusive at all but just hints that it might be involved.
hidave
Quote from: e2matrix on November 13, 2010, 12:29:05 PM
small caps takes long long time to notice gain, get a hold of 200v 2200 uf caps, PC power supply have some decent size caps. Or make your own. I have tried a 12 oz red bull can captret that I made, works very well.
plengo
Quote from: hidave on November 13, 2010, 12:18:13 PM
CORRECT!!!
I am confused now. PLEASE can you post a diagram (one of the above is ok) that is the ULTIMATE correct diagram hive? Not words but a diagram.
many thanks,
Fausto.
