Splitting the electron stream
Started by gravityblock, November 30, 2010, 12:08:47 AM
gravityblock
Quote from: juice on December 02, 2010, 01:48:26 AM
Henry has units Ohm*s. Therefore, you divide the inductance in henries by the resistance in ohms and you get the time constant, in units of seconds. That works just fine.
What you are doing is saying that 24 mH is special because if you divide it by 1.094 MHz*m, you get approximately 100*(1-2/e), a dimensionless constant. That doesn't work at all. What if you decided to use cgs units?!
Here is an analogy: I notice that my hand is 3*pi inches long. EUREKA! The secret to the universe is revealed in my hand! But only because I'm using English units... so it doesn't make sense. If I used metric units, the whole thing falls apart.
In science, it doesn't matter what units you use, but they must AGREE in your equations...
That's nice, but then why doesn't your equation take these into account? It shouldn't work if it ignores these factors.
Your analogy fails because you introduced a length or some other dimension based on a particular unit of measurement.  Of course the result will be different if you change to a different unit of measurement without a conversion between the two. Do you see how silly your analogy really is?  Here's my analogy. I noticed that my hand is 3% * pi inches long. Eureka!  The secret to the universe is revealed in my hand!  This works, and it's not due to the English units, metric units, or any other unit of measurement, but it does work because I used a percentage instead.  So it makes total sense.
e = Euler's number
1/e = 0.367879441  <----I will convert this to a percentage below.
1 - 1/e = 0.632120559  <----I will convert this to a percentage below.
1 - 2/e = 0.264241117657115356808952459677 or 26.4241117% is the difference between (1 - 1/e and 1/e) if allowed to round up  <---- Don't you find this interesting?  You should, because the additional digits in precision of 1 - 2/e leads to something else interesting.
Converting the above numbers to a percentage, we get 63.2120559% - 36.7879441% = 26.4241118% / 1.094 = 24.153667093235831809872029250457%  <----This is exactly what I have done in my calculations, and this method can work just like it did with the modified analogy of the hand and universe by using a percentage.  Leaving the % sign out doesn't change the fact that it can work.  I converted the 1/e and 1 - 1/e into a percentage, because the voltage will fall at 36.7879441% while the current rises 63.2120559% in a time constant.  Again, this makes total sense.  There is more than one way to do something, and it doesn't neccessarily have to be done in the only way you may be aware of.
GB
juice
Quote from: gravityblock on December 02, 2010, 05:15:29 AM
So you're telling me the universe calculates in inches? How convenient.
gravityblock
Quote from: juice on December 02, 2010, 09:44:43 AM
No, that's not what I'm telling you.  That is only what your silly little analogy is telling you.  Remember, I used the same figures you gave to me in your analogy.  If you gave me the wrong numbers or the incorrect data, then it's not my fault.  IMO, here's how the universe calculates.  The universe is an oscillating charge superimposed on an infinite point, constantly causing a deformation of space, continually exerting its influence on the un manifest, and automatically creating energy, and in consequence, matter. If this did not exist, nothing whatsoever would exist. This continual creation of energy in the Universe gives rise to an internal pressure in the nebulae which can be seen in the phenomenon known as "the flight of the nebulae."  As a result of this internal pressure they move away from one another.
You may raise the objection that this pressure is also applied in the direction of flight so that the internal pressure coupled with the external one would make them stable and they would not move apart, which would cause their mass to condense. My answer to this would be that energy created outside a galaxy tends to be drawn into the galaxy, condensing itself into material form. Thus we have an internal pressure coupled with an external decompression.
The flight of the nebulae prevents condensation taking place for three reasons: 1) This movement causes the interior pressure to disappear. However, nebulae appear to maintain an acceleration caused by an internal pressure within the Universe.  (2) As the nebulae move apart, that space which had been transformed into matter endeavours to return to its former state of primordial space in accordance with the law of rotation of masses in a magnetic field. This reconstitutes the energy that had been used for condensation of the matter, turning it into light, whose wave energy goes on decreasing until the moment of entropy is reached. This is what takes place on the Sun. Leaving aside the reaction that they bring about on the planets, the Sun's discharges into space are, in a sense, matter returning to its original state of primordial space.  (3) Light repels magnetic fields. Light from a myriad of suns in the various galaxies produces a very great force of repulsion on all the nebulae, and under this pressure they move away from one another.
In the first instance the oscillating charge superimposed on an infinite point supplied the power that brings about the deformation of space and the Sun, by an opposite process, turns it back into energy, thus re-establishing the balance.  That is why neither matter nor energy exist, but only deformed space, which is called matter, and what you call energy is nothing more than a phenomenon of transition between primordial space and deformed space.  This transition between primordial space and deformed space occurs within the "quantum transitional speed of 1.094 megahertz m/s".  If you conceive a limit, then what is beyond that limit?  Don't limit yourself in your thinking.
GB
juice
That was a nice sermon, and I agree with much of the character of what you said. I even like your interpretation of the orbo.
But your "equation" still has nothing to do with Znidarsic's constant.
gravityblock
Here's something to think about.
V = 12
R = 961
I = 0.01248
L = 0.961 - 1.0H
t = 0.001 - 0.00104
Fast rise time. The inductance is the inverse of the resistance. TC will remain relatively constant throughout all 5 TC's. Total rise time for current is ~ 0.005 to reach the maximum current of 0.01248 allowed by resistance. Maximum current is reached at the highest point in inductance. At higher RPM's, the Maximum current is reached in less time due to the inductance varying at the rate of the RPM, thus the system is more efficient at higher RPM. Basicly the total time for the current to reach it's maximum value allowed by the resistance will occur faster than the TC at higher RPM's, thus a "time variant field".  This is where the gain is coming from.  I think this is it!
GB
