New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
maw2432
Quote from: Omnibus on January 02, 2011, 11:59:25 PM
Good build, @maw2432. Waiting to see how it will behave with the magnets. Good luck to you too.
Thanks Omnibus,
I was thinking that it may work better in repulsion mode.  Just need enough weight on the stator to keep it pushing the rotor until it gets to the sticky spot and then lift the stator with leverage.   This way I only use the weight of stator to be moved.  With attraction,  I need to move the combined force of attraction (at the greatest attraction time) and the weight of the stator.   Hard to make small adjustments with an attraction design.   With repulsion,  I may only need to add some weight on the stator to until it is enough to do the job.   Your thoughts?
Bill
Omnibus
It would be great if you can make it work in repulsion mode only but somehow it is not always possible to avoid attraction. Probably you saw on the previous page my rig's idea: http://www.overunity.com/index.php?topic=10034.msg269285#msg269285 . I would be curious to see how you're going to accomplish repulsion all the way.
tbird
QuoteFront view of my test rig.
Bill
nice build bill!!
first thing that comes to mind, does the L mount for stator magnet (part that goes up & down with magnet attached) tend to go up unlevel?  looks like with the play you have in the guides it would.  if you get to a point where this bothers you, you might shorten (left side)the segment where the magnet is (extend the left guide in as far as possible) and put that length/weight to the right of the push rod part so it looks more like a T than a L.  that should balance it better so it would go up without favoring one side.
i don't see a provision for the 2nd small magnet mounted on the base in Roobert33's machine.  it appears to me he has used a lever there too but instead of making it easier to lift, he has made it harder (segment the cam hits is shorter than segment magnet is mounted on).  maybe he needed it to move further away to do the designed job.  do you think it has a spring to keep it down or just uses gravity?  is it in attraction or repulsion?
lots to play with and think about.
tom
It's better to be thought a fool than to open your mouth and prove it!
tbird
Quote« Reply #424 on: January 02, 2011, 03:06:55 PM »Quote@tbird re cam . Here is my opinion . Suppose that due to the requirements of the system , the total lifting has to happen during 10degrees of shaft rotion . To achieve this with a smaller cam , the lobe or ramp on the cam needs to be much steeper and shorter . with the big cam the ramp is longer and less steep . The amount of work done is the same in both cases and happens in the same amount of time . Imagine biking up two hills . Both are 100 metres high . one is short and steep , the other is longer and more gradual . Both have to be climbed in the same length of time . The amount of work done is about the same in each case . That is my gut feeling .
neptune,
i think you forgot the 4 or 5 friends that will help you over the short steep hill.  maybe i'm wrong, but shouldn't we count them?
tom
neptune
@tbird . I do A lot of biking ,and wether the hills are long or short , I get no help from any friends ! OK I know you did not mean that litterally . Work=force times distance , so if you lift the magnet a given distance , the work required remains the same . Think of me biking up a steep hill . If I use a lower gear , pedalling is easier , speed drops , and the climb takes longer . But I still burn the same number of calories .Gearing is just a continuous form of leverage . By the use of leverage in this machine , you could lessen the force needed to lift the magnet , but the lifting would need to happen over a longer time period .{more degrees of rotation] and this may upset the timing of the machine and would also extract the same amount of momentum from the rotating wheel . So, how about an opinion from some of you mathematicians instead of leaving it to an old retired truck driver like me.
