the majos differences of my AG-Cells
Started by Walter Hofmann, April 07, 2005, 06:20:02 AM
Walter Hofmann
Hi all,
I wana share after the most of the inital test's are done my experience with the group and the results from my reasarch.
MY Ag-cells have a totally different performance then any other battery and I even believe there is only magnesium cell's who  shows similar performance with the negativ point that they get verry fast consumed.
Many test have shown and are independently testet that they increase the output voltage under load not just with a rest time like other cells ,what no other battery can.
In many real time comparisson tests ( again done from independent outside tester) using the same load on batteries and my AG-cells it is shown that my cells outlast any other battery up to 100 times.
during my intensive reasarch I was aible to develop a graphit polygel which increase the output current up to 10 times or higher depending on the used formula ( proofen also from stefan hartmann) only with this development it made it possible to use plate versions in the cells.
further did I develop a alloy which also helps increase the output up to 30% but more importand it extend's the lasting time up to three times in comparisson to regulaer zamak #2 ( modern form of chemalloy) ( also proofen from stefan hartmann)
with this achievement's I now can put this power in pretty much any size required for the application, without any liquid ( means no spill) and a rectangular form what is verry conviniend
I can backup my claims in full with scope read out and if somebody can help me out here because I am not such a computer expert the read out is recorded on my computer in . txt format but I dont know how I can make it visible as a graph what would be easier to view.
I just wana share this with the interested people of the group.
greetings
walt
christo_g
Hello Walter,
You can just use MS Excel to make a graf of your test data. You have to take your txt data in the Excel sheet. Strait copy and paste depending on the txt format may do the job. Check Excel Help for how to make the graf - it is not difficult.
Cheers,
Chris
Hi All,
yes, the new cells from Walt are really good !
Walt only needs the money to build bigger alloy plates with a new oven
and then we can begin to build 12 Volts power batteries which will last
very long time.
It seems there is also some kind of double layer effect inside the cell at the
layer between the alloy-isolation-graphite surface.
It seems, when the cell dries, the layer is formed and then this layer generates the
energy.
These cells must not be wet to generate power.
Regards, Stefan.
Bruce A. Perreault
Stefan,
Yes, it is a hybred super capacitor. I have been demonstrating the plate design since around 1997,
using Windex as my conductive medium. I have been calling them Capture Capacitors. There is also
something about them that you guys haven't figured out yet. I am holding off telling anyone until
I am comfortably selling them as products.
                      -Bruce P.
Walter Hofmann
Hi all
one major difference is also that i am not using any other kind of chemicals as solarsalt and water. No windex or so ! the other major difference is that I am using graphite -poly gel powder mixture which has a surface area of greater then 1,400 Sqm/gram, the graphite plate what I am using are just used as transfer contact.
maybe something to my alloy which has in comparisson to regulaer zamak#2 ( chemalloy) which has a electrical conductivity of 15 and my alloy has a range of 28 to 30.
the theory as supercapacitor has a probleme , because there is no capacitor know or manufactured not even in labtest which generates electricity even under load, because like the name says a capacitor needs to becharged first, what is not the case with my AG-cells.
greetings
walt
