Free Energy? How about roughly a million tons of force?
Started by stvnjsha, August 30, 2008, 05:24:33 PM
You were progressing quite well on this device, anything new come out?
gravityblock
Quote from: Doctor No on December 28, 2010, 02:05:07 PM
Such big power can not be obtained at all. Even with newest, element 115 basing engines. They can have power of some 200.000 T but only as cluster of many small engines (about 200-400). Please remember that big tachyons engines built by Beluzzo in Breslau (today: WrocÅ,aw, Poland), had "only" 300 T of power.
Oh really?  You just put your self into the same category of those who said airplanes would never fly, the atomic bomb will never go off, etc.  What if we have a saucer shaped object, and there is low pressure on one side (vacuum), while the other side is subject to the full atmospheric pressure? With an atmospheric pressure of 1.033 kg. per sq. cm. we can calculate that the force operating on a saucer of 20 m. diameter is equal to 3,278,272.8 kg. This is one of the greatest forces available to us here on our planet.  Increasing the diameter of the saucer, will increase the force operating on the saucer.  Cathode rays or Lenard rays can create this vacuum effect by completely breaking down the atmosphere.  It will require extremely high voltage/current, but the force generated on the saucer will be much higher than the energy that went into creating the vacuum, just like the amount of energy required to detonate an atomic bomb is much less than the energy released from an atomic bomb.  An element 115 engine with no readily available source for the element 115 is good for nothing and it's not even capable of closely matching the force created by a potential difference in the atmospheric pressure of a relatively small diameter saucer of 20 m., Good luck with that!
GB
Doctor No
Of course,effect You had described it was used, but only for atmospheric flights. In space it is useless. You can only on power of free gravitons (tachyons) to count on. This atmospheric effect (better known as Coanda principle) was used in Beluzzo disc too, but mainly for better steering. So it was really an airplane, not for space flights intended machine.        And to element 115 engines. They were of course tested. But because of big impulse, they had disturbed stability of ocean.  The wave had over 300.000 people killed in this some 5000 from Sweden. (Unfortunately, swedish peoples are not so hard as theirs steel;-)). But they are really of not my big interest. You know, this is a time, everybody has of own ass to care:-)  Dr Adolf Nowak National Socialists Polish Workers Party           www.nsppp.bloog.pl
david lambright
Pi paradox solved
Pi is a reflection of the the infinite.....how? think of it like shells of numbers, the point being the center...the first shell is ones, the second shell twos etc...all the way out to the shell of nines...in Pi 3.14 the decimal point is reflected..... .314 is reverse Pi or Ip....the infinite point ....this model will show how hydrogen the lightest element, atomic number 1 at the center and all atoms fit this model....the infinite aspect of gravity and the finite speed of light will be explained to absolution ....in decimal math .314 x 3.14 is equal to .314x.314....the difference is the direction.....to or away from the I. [infinite point]...try this OK so if the theory holds true, a direction, a ray, a line, must exist..... .7129 and .6105195 are points on that line ....Edward Leedskalnin showed us these points.....here is what i know , the I. is the center, .314, .7129 and .6105195 will correspond to the diameter of a spike at those points.....look at it like this looking straight down at at the bullseye ones are the first orbit, twos are the second all the way down to the diameter of nines, which equals the event horizon of a black hole.... make a few calculations and see for yourself this model fits!......david
