Magnetic attraction vs steel laminating direction
Started by Low-Q, February 06, 2011, 05:33:16 AM
0 Members and 17 Guests are viewing this topic.
Low-Q
I have a dumb question, but better to ask than not finding the answer at all...
Anyways, does anyone know if there is a difference in magnetic attraction between a magnet and a laminated steel bar, depending on the lamitate alignment?
Bad example below, but I hope you understand.
|||| [magnet]
versus:
___
=== [magnet]
The direction of lamination are shown s above. Will the magnet be less/different attracted in the first vs. last example above?
Vidar
I think there would be a small difference that depends on lamination spacing. The larger the spacing the more attractive the vertical version would be I'd say.
Low-Q
Quote from: broli on February 07, 2011, 04:45:03 AM
Let's say that such a laminated steel bar are approaching a disc magnet in the most attractive alignment. Then, right under the disc magnets S or N pole, we twist the bar 90 degrees, and let it escape in the same direction, but with less attraction... I should know the "real" outcome, but it is an idea - at least :)
Vidar
exnihiloest
Quote from: Low-Q on February 06, 2011, 05:33:16 AM
There is not. The magnetic domains are of much tinier dimensions than the lamination thickness, so they are not dependent on the lamination alignment. The only role of the lamination is to avoid induced currents, with no consequences onto the magnetic flux.
Low-Q
Quote from: exnihiloest on February 08, 2011, 04:38:03 AM
Thanks for the infomation. I also tried this on a laminated steel core in the inductors we sell for DIY speakers. You're totally right.
Vidar
