Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
The Power To Be
This is a  full disclosure of the facts that will enable humanity to attain a sustainable civilization without the need for oil. Full non proprietory disclosure into the Public Domain by me, the origin inventor. The Power To Be.
PIEZOELECTRIC PRODUCTION OF ATOMIZE WATER WITH HHO FOR INTERNAL COMBUSTION ENGINE, COMBUSTIBLE WATER FUEL.
This system uses plain tap water with no electrolyte, all parts are off the shelf components.
The best solution to producing Water Fuel for Internel combustion Engine is to atomize water as being done in atomize water injection. You can buy an pond fogger that has piezo ceramic transducers. These piezoelectric transducers will atomize large volume of water with economical energy expense. make sure it's a piezoelectric machine that uses piezo transducers. what you need is fine atomize water fog and ultrasonic waves, in addition, piezoelectric crystals is employed to harvest surplus waves to make HHO, these ultrasonic waves would have otherwise been wasted as heat.
The result is a rich combustible atomize water gaseous mixture with HHO produced.
Make some zinc oxide crystals and and put it in wettable envelope. It will harvest surplus ultrasonic waves from the transducer and liberate water into HHO with piezoelectrochemical effect.
Zinc oxide crystals are synthetic and made from oxidize zinc . It is tetrahedral structures and have polar Zn-O bonds whis is ionic and highly piezoelectric. You need a durable envelope that will withstand the vibration, tyvek envelope might work, has to be wettable by water. The envelope is to contain the crystals from being splattered by the splashing water caused by the transducer. The crystals are very fine particles, nano meter sizes.
I have been trying to come up with a simple low temperature method to growing micro size single crystals at low temperature that is simple enough for anyone to perform. The mainstream ZnO single cystals are fused at high temperature and vapor deposited requiring complicated setup and technical expertise.
Ref:
How to make ZnO crystals.
more information on growing crystals to commercial standards, see this paper
nathan.instras.com/documentDB/paper-243.pdf
Piezoelectric HHO production.
http://www.greenoptimistic.com/2010/03/23/zinc-oxide-hydrogen-piezoelectric/
This is a simplified version for home use.
Please use all precaution, I am not responsible for anything that may occur.
Materials:
1lb. Zinc powder nano.
1 gallon ammonia cleaning (ammonium hydroxide)
Tools:
Hot plate with Magnetic Stirrer
teflon coated stir bar.
1 liter boiling flask with rubber stopper.
reflux condenser if available.
water bath.
thermometer
Dissolve 30 grams of ZnO in each 300 ml of 30% ammonium chloride/ hydroxide. This is best done by filling 300 ml of 30% amonnium hydroxide into the flask and place on stirrer with teflon bar. Turn on the heat to medium, Turn on Stirrer to low speed, #3. Slowly add zinc oxide to solution. When all ZnO is dispensed, cap flask and turn up stirrer to maximum, bring the heat up to 60 deg C and let it mix for 30 minutes.
Place flask in the Freezer and freeze solution to -0 degrees C.
When you reach this temperature, allow an additional 1 hr.
Before reflux, bath flask in a bowl of room temperature water for 5 minutes to avoid thermal shock and breakage of flask.
Set up water bath, large boiling glass bowl with water. Put your flask of cold solution in the water bath and set up reflux condenser with water tube, if you don't have one then just cap your flask tightly and turn on heat. Allow solution to heat up to 60 degrees C, maintain 60 deg C temperature for 2 hours, crystals will grow during this time.
Let solution cool to room temperature, Filter solution and recover crystals.
the crystals are self seeding. these crystals are not the typical large crystals that most people grow at home. the single crystals are very small, nano size, at this size, they are able to pick up all induced waves and convert waves into electrolysis of water.
When water is atomized with pond fogger, it is easily dissociated into HHO by the crystals. The gas mixture is rich in HHO, I don't know the H content but it is highly combustible. I got the idea after watching Dingles youtube video. You can clearly see the fog rising so I made the same unit in an old battery case and it works. The zinc crystals vibrates upon ultrasonic vibration generating it's own electricity and aiding in splitting of water into hydrogen and oxygen. This makes the gas mixture richly combustible and the atomize water will keep your generator running cooler with greater power generation. This can also be ported for motive use.
Obtain a small generator to learn on, you can get a 6 kw/hr electric start Champion genset from costco for $500 or so. Swap out the spark plug, put on a Diamond/Splitfire or high performance spark plug from autopart store. If you can make Krupa spark plug, that will work much better.
Construct a chamber to house your Atomizer and duct the fog into the engine air intake. Start engine with regular gasoline, then switch over to water injecion. It will run good and you can improve upon it by selective filtering of H and O2 seperately into a storage tanks so no gasoline/ diesel is needed to start engine, you can also add 2 and 3 stage tanks to seperate atomize water also and be able to precisely blend your gaseous mixture on demand according to your engines needs, thus allowing you to run all types of ICE, small engines, diesel and gasoline.
Copy of Krupa's Firestorm spark plug .
http://www.panaceauniversity.org/howtomakeplasmaplugs.pdf
replication Instructable.
Ultrasonic Water Fogger-The Mist Maker
http://www.mainlandmart.com/foggers.html
K006 is the transducer, there machines are bit too $$$ but they ship fast. buy em cheap from aliexpress or taobao, delivery takes 1 week.
zinc oxide is $11/ lb from ebay. ammonium hydroxide is $15 per bottle.
more reading
http://www.ionizationx.com/index.php?topic=1239.0
altrez
Qwert
Years ago I have read an article in a pop-tech magazine, that pure hydrogen makes steel parts brittle when contacting them, by fluxing away the structural carbon from the steel lattice. So, be aware of this when using your car's engine! Just "Google" it. My fast "Googling" research can confirm this here for example: http://www.springerlink.com/content/p475551841jhh711/
Sprocket
Hi.  Are the ZnO crystals consumed over time and at what rate?
markdansie
@The Power to be
Thank you for sharing
You have my attention.
Appart from the water does anything else get consumedor or need replenishing.
Having read your other threads you are a serious researcher.
The devil is in the detail...have you any figures for the power needed for instance to run the electrics to produce the gas to run the generator. IE is it possible to close loop.
I have seen no over device or replication of a device that has managed to do so.
Kind Regards
Mark
