Phonon boson and Higg`s boson interactions : Energy conversion in TPU
Started by Esa Maunu, March 31, 2007, 04:06:14 AM
Esa Maunu
Quote from: lancaIV on April 06, 2007, 06:08:31 PM
Hello Esa,
Robert Henson
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=US5252176&F=0
Phillip Burns,
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=US7098547&F=0
would be a nice test-configuration for the q.e.d. , or not ?
Sincerely
            de Lan?a
With crystals we can find very interesting properties, only by adding a pulsed static E-field.This static field alone can bend the crystal and this leads to piezoelectric voltage output from the crystal.
Esa
Esa Maunu
Quote from: archon79 on April 06, 2007, 10:46:10 PM
Does this mean that the frequency of the HV pulses have a direct relationship with the size/material of the core and not the coils?
If so this would explain some things, such as the fact a lot of people have wasted their time trying to match frequency with number of coil turns e.t.c
Also Esa what do you think of the statement posted recently, supposedly from Steven Mark, that the HV pulse generator must be located inside/within the coil and not external to it? Does this fit in with the Phonon Boson/waveguide theory?
Yes, it is a question with the size/material of the core, I see that coils are only used to direct an radial,pulsed E-field for the core, and in the core it happens that crystal structures are emitting phonon waves under applied E-field.
If we know the speed of sound in a core material, we can calculate a dimension for the core diameter.
In fact there must be more than one wave pattern around the core, so that first nested cylindrical field around the core has a same frequency as f1 control frequency has on the the core.
This leads to system, where frequency and phase is the same with first nested field, that exists on a distance 2x coil radius , and gives rise to energy transfer from the environment.
This is only a very short explanation.I have an excel calculation table to model and demonstrate this energy transfer system better.
Esa
Esa Maunu
Quote from: joe dirt on April 06, 2007, 04:46:40 PM
Is the concept you speak of the same as this, except without the nanotech?
http://www.physorg.com/news95001943.html
There are some basic properties that are the same, but with nested cylindrical fields around we can suck energy from the environment, and also we are using crystallic structures in a macro scale with the core.
Esa
We received,some months before, the news about the "non exspected",
=against the actual known physics laws/rules, the accelerated behaviour of
Hydrogen in Nano-tubes ! Factor: 20000X
Quantum/Partikel-physics works with Tunneling/channels,
also there should be find the effect of co-/adhaesion-forces !
Centrifugal and peripetal.
Are this Nano-tubes not carbon-based,
is there not the transmutation stage from :ferrit-carbon-boron ?
What happened with the ferro-magnetic-effect/force by this transmutation ?
Esa,
W= hxf , h= "numerische Konstante" ,
without to introduce me into the Fermi-world,
can you explain me,X-dimensional, the structure-importance of "h" ?
Sincerely
           de Lan?a
p.s.:
Helmut Reichelt ( from Schroedinger to the real Elektron-Gas-Cycle) works:
       http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DD287597&F=0
       http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DD208029&F=0
       http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=US2004046700&F=0
Esa Maunu
Quote from: lancaIV on April 07, 2007, 05:54:20 PM
Esa,
Sincerely
           de Lan?a
p.s.:
Quantum gravitation is a next big problem to be solved in quantum physics, there are many phenomenas that we can not explain.
Planck constant, h was proposed in reference to the problem of black body radiation.
Black body radiation is a radiation that is still left, even if all the other type radiation sources are removed.Planck constant is a property of the space itself and is the most used constant in quantum physics.
Esa
