Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
orosado
Quote from: turbosetch on April 07, 2007, 11:36:42 PM
On another thought back to the main design here I have considered building a electronic switch that could do the flip flop required in this model and have a controllable rate of switching.
Hi turbosetch,
I recommend that you first fully understand how Erfinder's device works, before attempting to modify the design.
Omar
allcanadian
I have said this a million times " semi-conductors are nothing like mechanical switches".
Electronics are lossy, they produce heat the lowest form of energy and can't handle high voltage spikes. You may as well add a bunch of resistors while your at it, that may help-Not.
barbosi
Just found (http://www.svpvril.com/bjerknes.html) an article about "Hydrodynamic Analogies to Electricity and Magnetism".
Following Keely's Laws of Attraction and Repulsion, Dr. Bjerknes presented at Electrical Exhibition in Paris an aparatus intended to show the fundamental phenomena of electricity and magnetism by the analgous ones of hydrodynamics.
Some vibrating spheres were shown acting like magnets and also in some experiments it looks like Leedskalnins North and South independent poles.
Note:
Keely's Laws of Attraction and Repulsion:
Law of Attraction
"Juxtaposed coherent aggregates vibrating in unison, or harmonic ratio, are mutually attracted."
Law of Repulsion
"Juxtaposed coherent aggregates vibrating in discord are mutually repelled."
In electric terms, applying a random (discord) frequency to a resonator there is not much success. However at resonance (concord) the energy spent is minimal.
Any corelation to paramagnetism and diamagnetism? Any chance that a magnet to exhibit both of them and in relation with another magnet, function of relative position to have concord or discord (attract / repel)?
When the Power of Love overcomes the Love of Power, there will be peace.
barbosi
From unification of 4 magnets we got a single [round] void point [neutral by J Keely] [Mind by W Russell]. Not only a point but a whole circle which is "unity" and "infinity" in sacred geometry.
How could work the principle "receive for regiving" in this situation?
Maximumgravity1
Barbosi,
You got me thinking.  I started to review again, it seems the line of thinking should head towards "what is a field", "how does it work, and what can it do in relation to the magnet and the other fields"?
"Receiving and regiving" seems to be the entire operating structure of this circuit.  It is all about inducing current from one coil to the next, creating fields, colapsing them, and using them to perform work through strictly electrical means.
Here is what I found:
Quote from: erfinderI repeat this is not a generator. The circuit is designed to concentrate fields, conduct fields, and causes the fields to preform work on the voided magnet ring as they pass through the circuit.  The secondary windings together make up a capacitor!  (Think Bifilar) A tuned HV capacitor!  The battery provides the the circuit with necessary currents (for best results a normal 12 volt automotive battery is suggested).  That which is taken from the battery is put back in the battery.  The primary transforms the current into one field, the secondary another.  The arrangement of secondary windings produce a field which is more electrostatic than magnetic, this field resonates with, and adds to the field of the primary.  When the fields of the primary and secondary collapse they return to the source, the secondary returns to the battery, and primary to the HV capacitor.
P.S. All currents alternate, even DC!  You should think of DC as Extreme high frequency AC.  DC currents must alternate or there would be no motion, the currents would not flow!!!  Its all about fields.
Grumpy,
We should talk,  I like that you mentioned Leedskalnin.  His wheel, and my magnet ring are one in the same, there is no difference in function, only in shape of magnets.  Excellent investigating!  Now you must try and understand how his wheel worked, you do this and you are light years ahead of the rest, and in a better position to help others.  Also I like your mentioning  Dr. Stefan Marinov, (electric motor without magnetic B-Field) getting warm!
Ask yourselves why Tesla only produced machines which operated at high frequencies, and high voltages!!!!!  DEAD GIVEAWAY!!!!  Stop thinking discharge!!!  Start thinking Stress (dielectric stress maybe?!?!?!?)  At the frequencies Tesla was using BACK EMF PERMIATED EVERYTHING!!!!!  High frequencies solidify space, according to Tesla!!!  At the voltages Tesla was using the stress (pressure) on space (aether) was ENORMOUS!!!.  Patent No. 568,176 page 2, paragraph 15 reads:
"The secondary of L which constitutes the source of currents of high frequency which may be applied to many useful purposes, as for electric illumination, the operation of Crooke's tubes, or the production of high vacua."
"OR THE PRODUCTION OF HIGH VACUA!!!!!!!!"
our limited thinking has us limiting this last statement to vacuum tubes......  Friends Tesla was talking about space itself, anywhere any space can be brought to a state of high vacua!!!!!
Use the force, uh I mean field,
The BACK EMF FIELD.  THE FIELD OF DREAMS!!!!!
EMF = PARAMAGNETISM
BEMF = DIAMAGNETISM
Quote from: Grumpy
Erfinder is right on the money.
The resulting field, which will usually penetrate all materials (actually it can be trapped and you get some sort of wierd non-radiating result) will be lobed due to the bloch walls of the magnet segments.  The coils at 90 degrees will cause this field to twist.  I am guessing that a true rotation of this field will not occur, but I am not sure at this point.  On second thought, it will rotate.  Anyway, this field has "momentum" characteristics and has been linked to gravity, yet its functionality still escapes modern physics.  I need to build it to complete my understanding of it.  Anything else is just a guess.
Magnetic field is a standing closed field.  This is the wrong "harmonic" as Erfinder would put it.  All magnets have a frequency, but I do not know how to determine this.  It is very limited compared to the field that Erfinder is talking about.  there are actaully two potentials at right angles to each other.  In particular terms of Einstein, one potential represents time and the other is space, but the time one has ben shown to exist without the space one - therefore the time one is considered primary.  The space potential will be in the center of the rotor and wrap around the ring.  The time one will be all around the ring and perpendicular to the axis.  I am not positive which one he is stimulating - perhaps both.
Charlie - Kinetic is secondary to the potential that creates it.  There exists only the potentials.
You must have potential of male and female to have a flow. (work of Walter Russell)
You can use the potentials to create a region of high vacuum or pressure.  Ion pumps are used to create extremely high vacuum.
I believe that 4 magnetic segments are required for the given arrangement - not that variations would not work - but you would need to know the concepts well to adjust the system.
Will take a little time to put this together.
