Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Slovenia
Great to see you again Power To Be!!
Quote from: The Power To Be on April 04, 2011, 08:08:38 PM
Genius is nothing but continued attention. The power of sustained attention grows with restrict distraction and solicitation. Great intellectual power turns on the ability to concentrate attention. To know how to exercise the attention, how to call forth it's full activity is the first success in learning. With strict attention, observation and learning, New knowledge is brought forth and the growth of extra sensory that develops into higher intelligence.
People, please for the sake of Man, please STOP.
What is a transducer?.
It is just a structured lattice of crystals tuned to a particular frequency. You can buy or make your own very easily.
So why would you waste your time and efforts wandering far off topic with distractions and speculations, all were working with here is Waves.
Learn to know what waves is, build different coils and observe. Learn the phases of elements, know their properties. Combine different element to achieve desired property. Everything has already been researched and published.
I've already told you to oscillate DC with a toroid, with your output AC, you amplify the frequency with a crystal. DC is pulsed at desired frequency/ oscillation, the lattice of the transducer crystals steps up oscillation and this allows atomizing of water into fine molecules. The induced waves is further amplified in oscillation to where the receiver ZnO crystals resonates to the state where the fine molecules of water ether bond is solidified allowing the release of H2 and O freely.
The same property applies to all matter, control the etheric bond and elements will separate freely. Metals, Rocks, Crystals etc. All you need is waves. Oscillating waves will convert elements to different phases, vapor, solid, molten etc, Do not use Heat as it is wasteful. You do not need to waster your time building electronic circuits, they are primitive, impulse and wasteful. You crystal and it's lattice is already complete build in tuning receiver/broadcasting circuits.
You do not need much to achieve this process, Really why do you people continue to CONFUSE yourselves?.
b_rads
Here is a site selling the Crystal ZNO mounted on substrate.
Someone willing to shell out and remove the crystal making process from the puzzle.
http://www.mtixtl.com/crystalssubstratesa-z.aspx
Brad S
Slovenia
April 4, 2011
FRC
Interesting Quote with reference to Powerme
Posted on Bedini Earth Light about crystals.
QUOTE=Armagdn03;136492]My work lately has centered on macroscopic crystal building using the seed patterns described by Aaity Olsen. Work coincides with this page (though I have not finished reading through it).
Powerme alluded to some very important topics, however I think it is always very important to distill process to be simple and effective for the layman.
One of the primary things noted was wavelength of the "cosmic rays" and how to interface with them. Nano crystaline material need not be used for this purpose. In such a case the corpuscles act in tandem with an overtone which corresponds to the energy's they react with. (a bell will respond to stimulation which matches the resonant spectrum peaks). but this can be done on a planar geometry...
Consider electroplating. Thickness of layers can be controlled through adjustment of temperature of carier liquid, time of treatment, current, NON ELECTRON FLOW ELECTRIC FIELD GRADIENT, etc....The purpose?
Quarter wave cancellation, as used in thin film optics as anti reflective coatings.
Anti-Reflection Coatings
It just so happens that germanium is translucent to the infrared spectrum....ever see a germanium lens? Did you know you can electroplate this and MANY other materials, some require very high voltage may be required for low conductivity semi conductors.
Germanium Optical Components
Oxides are important why???? most salts have a cubic of parallel piped crystalline structure. Oxide layer thickness can also be controlled. electrically "charged" elements find their line of economy within salts, this is the "marriage" of equal and opposite elements from a proper periodic table. for example note the location of potassium and bromine in making a very stable salt sodium-bromide. (spanning octaves 6-7)(equal and opposite locations about a line of economy)
ever wonder why "orgone" accumulators use alternating layers of conductor and insulator? We see immediately perhaps capacitor.....but there is more to it....How do you make an electromagnetic check valve?
Ever wonder why the house of Nathan Stubbfield was so warm when they entered? two plates, parallel, carefully placed a purposeful distance apart, dissimilar metals (each chosen for a purpose), impedance (air gap) in-between. Similar concepts, different use (to create heat). Perhaps Peter Lindeamann would like to expand on this topic.
Enjoy your experimenting![/quote]
FRC
Slovenia
Power To Be sent us an important message in (Post #428) of today.
We are getting very close to understanding some things that we were never intended to know thanks to Power To Be.  These secrets have been kept from us by very powerful people.  That said, there are other things going on in the background.  Anyway, study his post carefully and come to your own conclusion of what he is trying to say.    DON'T MISS WHAT HE IS TELLING YOU!!!
Slovenia
I just found a lost thread on Energetic Forum, "Plasma Effect - Cosmic Ray Amplification", which contained some important Power To Be information.  I added the lost thread to the Power To Be compilation file and updated the version on Scribd.
Link to Updated Version:
http://www.scribd.com/doc/52177573/Compilation-of-Power1-Posts
