Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Slovenia
Thanks Power To Be for the heads up on the Cosmic Orgasm.  I just ran into your post on referencing that again today and looked it up and found a useful book on the subject by Barry Carter.  It's very cool stuff indeed.  Thanks again for giving me that lead!!
For the rest of you, if you are interested, Barry Carter has several books on Ormus and the Cosmic Orgasm.  It may sound a little weird, but I found it very enlightening.
Slovenia
Here's a link to a Joule Thief Light weekend project for those of you who want to utilize the pierce circuit with jt light for frequency control like Power To Be did.
Joule Thief Light Replication
http://www.evilmadscientist.com/article.php/joulethief
Slovenia
I'm trying to put together the pierce circuit and joule thief light right now.  I could use some help from some of you electrical guys.  I don't want to screw this project up and Power To Be wasn't specific about what specific subcomponents to get for our pierce circuit.  He did mention the various components, but tell us any specifics about those subcomponents.  Well, I need to know what specific types of subcomponents to get for the following:
Joule Thief Light (Specific Subcomponents):
transistor  (Okay, have specific value of 2n3904 for it)
diode
#1)  Which specific diode would be best suited for this project?
Rectifier?
Power To Be mentioned needing  rectifier too.  This must be the diode he is referring too here?
Cell
#2)  What specific battery would be best for the application?
Toroid
#3)  What specific size of ferrite ring should be used for optimum results?
#4)  What size of wire should be used when winding the toroid for optimum results?
Resistor  (okay, have specific value of 1K for it)
Pierce Circuit (Specific Subcomponents):
Crystal Oscillator = (X1)
#1)  Which specific crystal oscillator?
Resistor = (R1)
#2)  Which specific resistor?
NOT Gate = (U1)
#3)  Does it matter which NOT gate?
Capacitor = (C1) & (C2)
#4)  Which specific capacitors are needed?
#5)  What size wire would be best suited for this project?
altrez
Quote from: Slovenia on April 09, 2011, 04:56:20 PM
diode
Rectifier?
Cell
Toroid
Resistor = (R1)
NOT Gate = (U1)
You really should use pot's in place of your resistors for the tuning it will make you life a lot easier. The JT is already everything you need n a circuit to replicate the correct frequency. Do you have a scope?
-Altrez
The Power To Be
Quote from: altrez on April 10, 2011, 01:42:47 PM
-Altrez
Right, frequency is easily controlled with cap and coil, just like in TT, where each coil is tuned with matching cap. Horizontal arrangement produces consistent electrostatic effect needed.
I have produce amazing ionization of atomize water with a differential  exciter  running at over 5 milion cycles per second.
Altrez,
Did you look into zinc sulphide for your project?.
