Elisha
Hi, but what is this radio silence?
Is the replication working?
Mavendex where are you?
casman1969
Finally!!!!
Steel dougnut arrived today. Now I know the size of my secondary torrid and can begin to build it. As with others I must juggle my time. Between my company, civic duty and waging war on an out of control, completely corrupt Judiciary in TN it is getting harder and harder to create research time. But this one holds so very much promise that I just can't wait to begin.
Don't equate others silience with inaction...
Magluvin
Quote from: Elisha on April 25, 2011, 03:54:02 PM
I think its safe to say, build it.  ;]
Mags
Mavendex
Quote from: aaron5120 on April 27, 2011, 12:58:43 AM
Hi, @Mavendex,
I have been reading quietly this thread so far, and did not post anything here. But I am very interested to try replicate your latest resuts of the Gabriel Device Version2.0
I have some crucial questions to ask before I proceed to buy the components for the replication, which are not cheap. If you don't mind, here they are:
1) The primary should be tin plated copper wire, insulated in plastic, AWG #24, one layer, wounded counter clockwise( from right to left, in opposite direction of the clock hands), right?
2) The primary core shoud be soft iron toroida halves, those used in the exhaust tubing( donuts) ?
3) These halves shoud be insulated one from the other i order to prevent arcing from the secondaries windings, right?
4) The secondary windings will be 300 turns of AWG24 magnet wire wounded clockwise( from left to right, in the direction of the clock hands), right?
5) How to calculate the proportion of wires used both in the primary and the secondary? How many turns in the primary for how many turns to the secondary?
6)The device operates basically in the 50Hz/60Hz frequency of the public grid, right?
7) The toaster's purpose is to limit current flow in the primary, as a resistive current limiting component, right?
8) The secondary loading should be strictly resistive, such as common light bulbs, right?
9) There is no need for impedance matching for the secondary loading, right?
For the benefit of all the replicators in the thread, it would very nice if you can answer these questions openly in a public post in the Gabrial device thread.
Thanks a lot, and please keep on experimenting, and we appreciate you very much for open sourcing this discovery.
aaron5120
Hello I will answer as best as I can,
This version with the new shell needs to be recalibrated for wire and what not I did change more than one variable and have to compensate for these changes, be assured for every 1 watt in we get 12 out thus far.
1)the primary I have found, should no longer be tin plated copper and normal magnet wire  will work better in this instance of the new shell, optimal sizing of wire is still being experimented with I have wound it counter clockwise and towards myself it does make a difference if you are winding away or towards your self, the toroidal halves
2) I am useing are mild steel or cold rolled steel, feel free to experiment with other metals as this is a cage.
3)yes the halves should insulate from each other other wise the effect is no longer present
4)The direction of the primary is the same as the secondary as far as winding, conventional winding ratios are out the window, how ever much is on the secondary has a ceiling applied and will always be present. currently I have 3.1 ohms of resistance 16 awg wire on the secondary which is yielding a ceiling of 180 volts
5)on this current size and still needs to be calculated and restructured as far as the math goes but as is with current setup 97 turns of the primary will get you to the sweet spot, again winding ratios calculations for conventional transformers are null
6)yes that is how I made it although I do plan to experiment with other frequencies for other projects
7)yes the toaster is my limiter, I will be changing that soon
8)yes to measure your output I would use light bulbs, wear sunglasses and have a meter (be advised if you turn off the secondary before the primary you will get a backspike)
9)impedance matching as far as I know there is no need, again the device is being recalibrated
I am posting these questions in good faith and hope everyone's replications can match or exceed what I have done.
Be aware patent application is being filed on this device for commercial benefit and to get the ball rolling a bit quicker I am doing this with Thane Heins, also be aware I believe everyone has the right to free energy, and if you replicate/duplicate for your own self and supply power for your own self and build it your own self  without making money and saving money doesn't equal making money, that is quite alright with me more power to ya. If you so choose that you would like to make money with these devices I would contact either myself or Thane to setup licensing which he has a well thought out agreement that is mutually beneficial for all parties involved.
Dave
Mavendex
forest
Although I understand your motivation (even more now when I became unemployed) I think you cannot patent it because it was patented by Tesla. You can patent your embodiment but still I think it's not fair.
For example I want to test other embodiment with another slightly different arrangement (like secondary bifilar coil for example) and ideas which I think were used previously (but not patented due to suppression) and your patent would shutdown the way for me to sell it locally.
However I respect you and your decision.I believe you are honest person.
P.S. Once I had a dream. A dream about a couple of friends from OU forum working together inventing and producing device which will help poor people a little. And they invest their time and efforts and money to invent another device even more  useful.
