Muller Dynamo
0 Members and 20 Guests are viewing this topic.
Bruce_TPU
Quote from: romerouk on May 08, 2011, 09:46:02 AM
The generator coils experience cemf depending on the load but at some point the speed goes up now down.
People should see the whole picture, don't look at a single coil, look at the other coils too at the same time.
Looks that we have a member(Microcontroller) that is 100% sure that this is a fraud, ha, ha, well u got me :)
Hi Romero,
Microcontroller and others like him are trolls.  They never have anything constructive to add, and they never build, nor test anything.
He and his buddies are best left ignored.
I am with you, all things are possible...
And I would have to add, that you are correct about looking at the interaction of all of the coils, vs. magnets, and not just one.  I posted some time ago, in EM's thread, that I had found a patent that showed that the best coil to magnet layout to remove cogging was 1.5    - In other words, 12 coils and 6 magnets would be no good, because 12/6 is 2.  But 12 coils to 8 magnets is 1.5 ratio.  1.5, 2.5, 3.5 all work.  This is another reason, that with my coil discovery, I am not overly concerned with cogging, but I of course still need to test and prove it.
Cheers,
Bruce
Cherryman
I ordered the magnets.
Next step are the coils.
As I'm an electrical noob i have a few silly questions:
I'm i correct i can use a (in this case 0.125 ) wire , take 7 strings connect the endings and wind those all at the same time 300 times around the coil ?
I could not quite see how the coil is connected to the stationary disc.
Could someone tell me if it would be A, B, C or D?  Or Else?
romerouk
Quote from: Cherryman on May 08, 2011, 10:43:06 AM
The answer is B, the core is not in contact with the magnet but goes half way
FreeEnergyInfo
i_ron
Quote from: hoptoad on May 08, 2011, 08:02:11 AM
It sure does Ron!
I'm looking forward to seeing your build. I've seen previous results of your mechanical skills
so I know you'll do good.
Looking forward to (hopefully) some more positive results and the ensuing lively discussion.
Heres something Romero said back on page 5.
"The distance between the coils and the rotor must be adjusted depending on the magnets used, core... Too close is not neccesary good."
Sound familiar to you Ron ?. Someone I know has mentioned this in detail before, on another site?.
It may have even been me !! LOL.
P.S. - Thinking aloud ... Open Magnetic Sytems. They're full of surprises!  LOL
Cheers all .... KneeDeep
Hi Hop!
Thanks, but boy, we are in some good company, you, Ben, Luc, nali, Gyula, and some other names I recognize...all the big guns....
Plus a few agenda workers, looks like the same bunch that worked so hard to derail Rosemary's various forums.
Interesting correlation here in the ratio of core size to magnet diameter, as in the Adams motor.
New ideas also on the multi strand. I always stayed away from it because of the cleaning to solder task... but I see it advertised as "solderable" ...so I took an old CRT coil and tried it, sure enough it solders like a charm!  Couldn't unwind it though as it was too well glued together and broke.
Yep,rotor up and running, to the point of doing some coil tests next
Take care
Ron
