Muller Dynamo
neptune
@ Cherry man . See also my reply number257 on page18 .
i_ron
Quote from: bolt on May 08, 2011, 09:08:04 AM
I think you completely missed the point of what i was saying.  First it is not the replication that is important it is understanding the method and using Re-gauging on the back end of the coils to null out the lugging. This is a magnacoaster method and something some of us have discussed for a long time.
The drive of the rotor is not important as the pulse motor is only used to provide rotation. Any method of rotation can be used so long as its very efficient.  Already you will see no two devices will be the same as everyone will use the materials they have available to them. The magnets will be different strengths, the cores wound different, different core materials, the number of coils and magnets are probably going to be different BUT they all have a good chance of working if the re-gauging back end magnet is carefully selected to null the BEMF.
And Indeed Romero has suggested others try bigger coils and rotors to get more power. Alike the Joule Thief no two are the same yet most of them work!
For using 3 phase RV provides cheap method of construction with professional bearing and platform to mount a rotor. The perspex doesn’t come cheap either. A3 sheets of the stuff 12mm thick cost a small fortune!! RV provides an extremely efficient drive motor which can spin a very large rotor down to a few watts.
http://youtu.be/duWxzwLEMxM
Now bolt the genhead stator and rotor direct to the motor shaft and you got your muller without using pulse drive and ALL the coils then become generator coils.
I second baroutologos.
The regauging theory was put forward to quickly. The key to romero's device is the tuning of the coil under load. This indicates a reaction with either EMF or BEMF as the principle cause. Regauging may play a part but how can you put this out with no data?
The RV is a great toy, I use mine for all sorts of data gathering but i know it doesn't have any use at 20 watts, the slightest load and the draw goes sky high.
It is the replication that is important... then comes understanding, from why some will work and some won't.
Ron
baroutologos
Hey I_ROn,
Its nice to see you involved in this. Great machinist skills with right guidance will end up to the desired replication, God willing.
i have not the slightest intention at developing any theory or hearing others'. In the end of the day, the real things are that stay and make a difference.
If you track the way ROmero has always worked, he listens to everything and experiments with everything in his own way.
Personally it was beyond my powers to do that. Since i lack resources and imagination to do so.
Lets keep this great thing going, and anyone makes a positive contribution.
scratchrobot
Would it be possible to create litz wire from normal multistrand wire by maybe spraying some insulation or taking it trough a bath? Maybe someone tried this?
ramset
Gents
Regarding The "Nasty" Posts!
Looks Like Stefan Is Keeping The Vibes Positive over here! [deletes the "nasty"]
Just the Way Romero Likes it!
History In the making!!
Chet
Thanks Grandma
