Muller Dynamo
neptune
"You never change things by fighting the existing reality.To change something , build a new model that makes the existing model obsolete ." R Buckminster Fuller .
merlynmetal
Wasn't the Orbo able to cancel BEMF? Also wasn't it's rotor levitating on magnets or something?
bourne
Quote from: neptune on May 14, 2011, 04:19:55 PM
So true.
I seem to remember Bucky was good at making people stand in awe of simple 3D solutions to 'impossible' problems.
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
CLaNZeR
Quote from: merlynmetal on May 14, 2011, 04:30:57 PM
E-Orbo did cancel BEMF with it's arrangement, but you literaly had to be within 1mm to get flat lines on the current and voltage.
I spent alot and I mean alot of time on it. Was very difficult to publish the results of tests though, because of Steorns NDA, but yep you could get rid of BEMF.
But since then the Rodin Starship coil actually gives better results than the E-Orbo. Check out the video where I demonstrate a near perfect flat line on the current and voltage.
http://www.youtube.com/watch?v=7gWR6nOPp28
Looking forward to getting the scope connected to this muller generator and seeing how it looks.
Cheers
Sean.
http://www.overunity.org.uk
CLaNZeR
Okay doing what I can, until all the other parts arrive, so getting some fiddly bits are out of the way.
Cut out the Bobbin ends and glued to 6mm ferrite. Picture attached.
I was going to mount them on the stator plates and wind in situ like I did with the Rodin coil
http://www.youtube.com/watch?v=Ol7n3Z7vpMA
But have decided after some calculations that maybe it is better to wind them the traditional way, so will drag out the old stepper motors tomorrow, cut out 18 more bobbins end and glue them in place.
Here is video of homemade coil winder.
http://vimeo.com/10471510
Ferrite was cut down, by modifying CNC machine as video below
http://www.youtube.com/watch?v=vZoRd8MV5qI
Cheers
Sean.
