Overbalancing wheel
Started by SPANG, May 10, 2011, 12:46:30 AM
AB Hammer
Vidar
I believe you are correct.
_______
Stefan
QuoteIs the red and the pink wheel fixed to each other ?
As it is drawn, I believe they are. Will this be the final outcome? I doubt it.  The lower smaller wheels are an attempt to increase torque. I am not sure they will do what is needed. Stress lock up is the first and biggest conflict to break through. So the question is. How can we get the overdrive to become a positive driving unit without the possibility of stress lock up, or to much back torque. If we can achieve this? We may have a real possibility.
A gravity additive may be needed to achieve this.
Alan
With out a dream, there can be no vision.
Alan
SPANG
Hi All,
       From the amount of 'feedback' I've been recieving about the role of the bottom-wheel, I feel
compelled to offer my explanation.
The role of the bottom-wheel, is to supply the top-wheel with what it needs.
The top-wheel needs two identical forces,  (10kgs each) delivered by chains ---------(e.g:),
1 at 1mph, and 1 at 2mph.These speeds are only estimates, and will (most probably), move at a
greater speed. But, the RATIO remains the same    2:1.
The 5 wheels, that ARE (colectively), the bottom-wheel,  at their different sizes, facilitate these
speeds/forces.
Hope that helps?
Once again, I must stress, the weights (forces), and the chains' speeds, are only EXAMPLES!
SPANG.                (BILL.)
1 at 1mph, and 1 at 2mph.  The 5 wheels, the bottom-wheel set-up cosists of
SPANG
Hi All,
       I realy don't know where to 'post' this little 'ditty', so I've decided to 'post' it here.
                                         An Ode To Tension
                                         ________________
Tension weighs nothing.
Tension CAN produce a force that matches gravity ---- even betters it!
Tension has many advantages over gravity, one of them is; it can produce a 'gravity-like'
force in ANY direction ------------- gravity can't.
Tension can be 'turned off' ----- gravity can't.
A Tensioner added to a chain, can make that chain 'appear' as if it WAS a weight -------
but  isn't!
TENSION CAN WORK IN SPACE, GRAVITY CAN'T!
I think Tension, is more versatile than gravity.
I bet some of you 'out there', can think of even more ------------ let's hear them!
SPANG.              (BILL.)
SPANG
Re; reply # 95
Stefan,
          Yes they ARE ------ SOLID!
SPANG.              (BILL.)
SPANG
Hi All,
      I think that ALL o.u's, overbalancing wheels etc..,
will owe their functioning to the manipulation of KNOWN
physics ------- NOT new physics!
As far as I know, ALL types of o.u.  devices, use known
physics.
SPANG.         (BILL.)
