PhysicsProf Steven E. Jones circuit shows 8x overunity ?
Started by JouleSeeker, May 19, 2011, 11:21:55 PM
hyiq
Hi All,
I did not wind the Bi-Filar with a seperate single filar. But, I did wind another Bi-Filar and tested that.
N = 37
Nice result so far. I also started going through parts to see if I have exactly the same parts to build two circuits to try self looping. I hope tommorrow I will have two circuits running and then try to self loop.
All the best
  Chris
Bruce_TPU
Quote from: hyiq on June 06, 2011, 08:27:23 AM
Hi All,
N = 37
All the best
  Chris
Hi Chris,
So your new winding nearly doubled the output?  A drawing of your bifilar when you have some time, as well as size wire, inductance, etc.  Very impressive results to say the least.  Was that the only thing that you changed from your version 4?
Cheers,
Bruce
dimbulb
What do you think about an
Amidon FT140A-J
goldmine is sold out of the G6683
hyiq
Quote from: Bruce_TPU on June 06, 2011, 10:06:34 AM
Hi Chris,
Cheers,
Bruce
Hi All, Hi Bruce,
Input = 4.612 mw
Output = 168.32 mw
[EDIT : Wire Gauge is 0.8mm, 9 turns Bi-Filar, Ferrite toroid is 29mm long, 18.5mm OD, and 10mm ID]
Its a little messy but here it is.
All the Best
  Chris
hyiq
Hi All,
There is a voltage drop accross R3. Here is the updated figure for the input: 5.537 mw
All the best
  Chris
